WILL B16 11;5;1 PISTONS WORK IN A GSR BLOCK WITH A B16 HEAD
Bought a set of wiseco pistons 11;5;1 cheap off a guy needing$ wiil they work in my gsr block with a B16 head with stage 1 crower cams WILL I HAVE ANY CLEARANCE PROBLEMS
I would say that they will work but your compression ratio will be at least 12.5-12.7:1 when completed assuming the head hasn't been milled or the block hasn't been decked, using a stock head gasket and valves. Clearance shouldn't be an issue but you WILL have to clay the clearances between valves and piston to find out how much room you have to adjust your cam gears. Good tuning will be important.
iam gonna give it to yhe machine shop and they are gonna clearance it make sure there will be no problems just making sure it will work
