Getting new headers but don't know if it will fit what i have.
Old Dec 8, 2006 | 07:47 PM
Import_spoon's Avatar
Default Getting new headers but don't know if it will fit what i have.
Like title says i'm getting new headers but then i have a Ls swapped in my civic HB and i don't know if the headers will fit where it meets the exhaust because i think the civic pipes are shorter or different. The pipes are aftermarket stainless steel 2.5' piping. Let me know thanks
Old Dec 8, 2006 | 07:52 PM
99Geeezer's Avatar
Default Re: Getting new headers but don't know if it will fit what i have. (Import_spoon)
the header will most likely fit the motor, if it lines right up to your current exhaust system, I don't know. I'm not sure but maybe some minor exhaust work will need to be done.
Old Dec 9, 2006 | 11:27 AM
Default Re: Getting new headers but don't know if it will fit what i have. (99Geeezer)
I'm thinking it might work but previous said the exhaust pipe is a bit longer.
Old Dec 9, 2006 | 12:32 PM
Padawan's Avatar
Darth ModerVader
What manifold is on there now?
Old Dec 9, 2006 | 02:55 PM
Default Re: Getting new headers but don't know if it will fit what i have. (Padawan)
B series
Old Dec 9, 2006 | 02:57 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Import_spoon &raquo;</TD></TR><TR><TD CLASS="quote">B series</TD></TR></TABLE>
Can you be more specific?
Old Dec 9, 2006 | 03:31 PM
B series ls motor B18B
Old Dec 9, 2006 | 03:34 PM
Padawan's Avatar
Darth ModerVader
Well, if your current manifold is from a B18B and it is working with your setup, if you order a header designed for the B18B, it should fit fine.
Old Dec 9, 2006 | 04:23 PM
oh alright then. The previous owner said the exhaust pipe was a tab longer but i think it should be fine.
Old Dec 9, 2006 | 04:49 PM
Padawan's Avatar
Darth ModerVader
I still don't quite understand. If you currently have a B18B manifold installed, and everything lines up properly, why wouldn't a header for a B18B also fit?
Old Dec 9, 2006 | 05:05 PM
i don't know thats why i was asking. I'm new to cars that have swap.
Old Dec 9, 2006 | 06:15 PM
HandleTech's Avatar
Even if it doesnt fit, the only difference will be the distance between the header and the exhaust piping...take it to a muffler shop....
The local muffler shop did me up for $35
with new donut gaskets. Its a common isue with
changing engines and/or headers.
Dont be intimidated...just make it work.
Old Dec 9, 2006 | 06:18 PM
Default Re: (FuknHeeHAw)
oh alright then. Thank you very much!
xander1100
Feb 11, 2009 06:23 PM
mike03,95civic
Mar 5, 2008 05:38 PM
Crx_707
Jun 22, 2005 12:48 AM
WRTEG
Apr 17, 2004 04:34 PM
