Just Did B16 Swap, HELP ME
Old May 10, 2002 | 08:48 PM
CanadaCivic's Avatar
Default Just Did B16 Swap, HELP ME
Hey,i just got my b16 in, i didn't try to drive it cause i didn't have tranny fluid in. I just started it so i could check for codes. Now we tryed to push the car out and we can't, the passenger side wheel simply will not turn. We had some problems with the axle on that side but i'm not sure that would make a difference. Could some one shed some light on this problem??? I also put in in neutral and held the clutch in just in case it was stuck in gear.
Old May 10, 2002 | 08:53 PM
EP3_05's Avatar
Default Re: Just Did B16 Swap, HELP ME (CanadaCivic)
What axles and intermediate shaft are you using??? Did you pop the sealing ring and dust sheild off the axle and hub???
Old May 10, 2002 | 10:07 PM
Overkll's Avatar
Default Re: Just Did B16 Swap, HELP ME (91civic)
That's my guess too. It's probably the sealing ring. Did the same thing, when I thought someone else popped the ring out. Found out AFTER everything was put back together. Wheel wouldn't turn at all. Took it apart and everything worked fine. The second time is ALWAYS easier HTH, Overkll.
BTW, no codes , eh? Good stuff. I HATE hearing people saying they run with codes. TROUBLESHOOT and fix them! Make the car run like it was supposed to.
01_em2
Feb 6, 2010 12:50 PM
aznnay
Feb 3, 2006 02:45 AM
civic889802
11
Dec 28, 2005 11:13 PM
ShadyBAB
Dec 28, 2005 07:31 PM
OBD1Kenobe
May 15, 2004 07:22 AM
