I feel like such a Douche but can someone explain to me what Bore and Hone is ?
Old Dec 8, 2006 | 02:41 PM
Leo.'s Avatar
One Day
Default I feel like such a Douche but can someone explain to me what Bore and Hone is ?
Im sorry guys but can someone explain this to me ? I search but I could not find anything
Old Dec 8, 2006 | 02:45 PM
Mykizism's Avatar
Default Re: I feel like such a Douche but can someone explain to me what Bore and Hone is ? (2000Plus)
bore is when you make the circurmference of the cylinder bigger. or bore can mean the diametere of teh cylinder
hone is when u use a tool to refinish or finish the cylinder walls, making it a rough or smooth surface depending on builder preference
Old Dec 8, 2006 | 02:48 PM
Leo.'s Avatar
One Day
Default Re: I feel like such a Douche but can someone explain to me what Bore and Hone is ? (Mykizism)
So a bore taking a percentage of the cylinder wall off to either refinish or make more room for a slightly larger piston ? and a hone is just to make the cylinder wall smoother ?
Where is a good bore and hone in los angeles
Old Dec 8, 2006 | 02:55 PM
boostedblkef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000Plus &raquo;</TD></TR><TR><TD CLASS="quote">
Where is a good bore and hone in los angeles </TD></TR></TABLE>
your going to look for an automotive machine shop and i would guess that in la there's one on every other block
Old Dec 8, 2006 | 02:56 PM
ExospeedAMcrx's Avatar
what are you trying to do first?
Before a final bore and hone is done to the cylinder walls, the machinist will measure the piston that you are going to use and calculate the necessary clearances for the piston and the walls. Each brand of piston will require a certain amt of distance between the piston itself and the cylinder walls, hence the name piston to wall clearance.
qazaq
Jul 14, 2007 04:20 PM
Rosko
12
Mar 17, 2007 04:09 PM
s2kkid
Honda S2000
Jan 10, 2006 08:17 PM
Gant
May 28, 2005 08:10 PM
THE *FOB* MOB
May 23, 2002 02:11 PM
