350WHP 13x22x9 m&h's enough?
Old Dec 8, 2006 | 01:52 PM
Jason703Racing's Avatar
Default 350WHP 13x22x9 m&h's enough?
Car should be tuned to around 350whp this weekend and just wanted to see if anyone has ran that much power on a set of 13x9x22 slicks.
thanks
Jason
Old Dec 8, 2006 | 02:04 PM
wHOAlly's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (Black00em1)
wat tranny, wat redline?
Old Dec 8, 2006 | 02:26 PM
Default Re: 350WHP 13x22x9 m&h's enough? (wHOAlly)
b16 lsd tranny revving 8500
Old Dec 8, 2006 | 02:35 PM
wHOAlly's Avatar
22's u'll be shiftin into 5th gear. 23's would be better. but if u have them arelady and rev it out higher, try that
Old Dec 8, 2006 | 03:29 PM
sleeprhatch's Avatar
i had that set up you really need to go bigger. you will cross the line in 5th
Old Dec 8, 2006 | 06:08 PM
TeamNextGenChris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wHOAlly &raquo;</TD></TR><TR><TD CLASS="quote">. 23's would be better. </TD></TR></TABLE>
i was thinking more along the lines of 24.5"...especially with that tranny.
chris
Old Dec 8, 2006 | 06:36 PM
.RTErnie's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE>
dito
Old Dec 8, 2006 | 07:00 PM
ALLphilthyDC2's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (Eric@HorsepowerFreaks)
350WHP turbo or all motor? whats the setup?
Old Dec 8, 2006 | 08:10 PM
dunkd's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (ALLphilthyDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLphilthyDC2 &raquo;</TD></TR><TR><TD CLASS="quote">350WHP turbo or all motor? whats the setup?</TD></TR></TABLE>
350 all motor hes gonna need some 28" slicks.
Old Dec 8, 2006 | 09:52 PM
redboost10's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (dunkd)
if your turbo, you need the 24.5's. i was making the same whp that you plan to make, and i was still spinning the 24.5's, i didnt get much seat time, so didnt mess around with tire pressure that much, but as far as i got, i was only spinning off the line of course. i was launching around 7500 rpm, b16 tranny, 14 psi of boost. no 2step. 24.5's for 350 whp fi setup is perfect.
after reading the post below from exospeed, i figured i should add that i was shifting at 8500 rpm, going through the trap in fourth gear around 8250
Modified by redboost10 at 7:09 AM 12/9/2006
Old Dec 8, 2006 | 10:01 PM
ExospeedAMcrx's Avatar
Default Re: 350WHP 13x22x9 m&h's enough? (redboost10)
you can still get away with the 23" but with a rev limit under 9K and a b16 tranny, that combination it is best to use the 24.5" so you're not having to get into 5th gear.
Old Dec 9, 2006 | 12:09 PM
Default Re: 350WHP 13x22x9 m&h's enough? (exospeedAMcrx)
Its a turbo car.
Old Dec 9, 2006 | 06:17 PM
A.E Motoring's Avatar
24.5 FTW, u will be going into 5th with anything smaller, unless u get your redline extended. i use 24.5 and im in 4th by the time i finish the quarter, with a b16 trans
Old Dec 10, 2006 | 08:12 AM
wHOAlly's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris &raquo;</TD></TR><TR><TD CLASS="quote">i was thinking more along the lines of 24.5"...especially with that tranny.
350 whp isnt enough to spin em...
trust me, i was in the same exact boat.
22x9's even with a shift to 5th netted me faster et's.
22" 11.6@117mph (5th gear shift)
23" 11.7@120mph (didnt get to play with these much but i coulda gone faster than the 22's)
24.5" 11.9@124mph
Old Dec 10, 2006 | 08:53 AM
redboost10's Avatar
i know 363whp is enough to spin 24.5's
Old Dec 10, 2006 | 10:28 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redboost10 &raquo;</TD></TR><TR><TD CLASS="quote">
i know 363whp is enough to spin 24.5's</TD></TR></TABLE>
and i know that roughly 300WHP is enough to spin 24.5"s.
Chris
isaacson06
Aug 25, 2007 09:14 AM
superhatchbackbros
10
May 30, 2006 10:19 PM
SoOHiGH
May 4, 2005 02:13 PM
EFHbSi
Apr 30, 2005 07:50 PM
CA6VTEC
Mar 20, 2004 08:02 PM
