What clutch are you using?
Old May 10, 2002 | 07:41 PM
Gangsta Accord's Avatar
Default What clutch are you using?
just wondering what clutch are all of you with h22's using. and tell me what kind and what model and let me know how its holding up and how long have u had it and also would u buy the same clutch agian if u had to. because im having a hard time choosing a clutch duno weather to go CLUTCH MASTERS STAGE 3 OR 4 but i do want somtn to last long
Old May 10, 2002 | 08:18 PM
TimeRacer's Avatar
Default Re: What clutch are you using? (Gangsta Accord)
What's your end goals for the car? Do you NEED it to hold that kind of pressure? If you're leaving your car basically stock you don't even need stage 3, just go with 2 or 1.
~Doug
Old May 10, 2002 | 08:26 PM
Default Re: What clutch are you using? (TimeRacer)
im running a drag 3 turbo kit
[Modified by Gangsta Accord, 5:28 AM 5/11/2002]
Old May 10, 2002 | 08:43 PM
Quaalude's Avatar
low boost = stage 3
high boost = stage 4
Old May 10, 2002 | 09:36 PM
mattmw88's Avatar
Default Re: What clutch are you using? (Quaalude)
I've "heard" great things about clutch net so I bought a stage 2 clutchent. As soon as I install it all I'll let you know how it all goes- I got miny for 300. (or a stage 3/4 for 300)
Old May 11, 2002 | 10:49 AM
Mike95lude's Avatar
Clutch Master Stage 3 here. It drives just like a stock clutch basically. I haven't really abused the clutch too bad but its holding up well I'd say.
Old May 11, 2002 | 02:43 PM
illusion's Avatar
stock clutch and its starting to slip on the 1-2 shift
Old May 11, 2002 | 03:02 PM
SilverLudeSi's Avatar
New User
Default Re: What clutch are you using? (illusion)
I got a clutchnet stage 2 because a lot of people recommended it. However, when I went to inline pro in VA today to put a deposit on my engine work, they said clutchnet is the worst clutch they've ever seen. They said it wore out on some guys car in 5000 miles and dug a 1/4" groove in his flywheel. They only use clutchmasters supposedly. Seems like everyone has a horror story about every clutch brand. I don't know what to do.
Old May 11, 2002 | 03:12 PM
CD8's Avatar
CD8
Default Re: What clutch are you using? (SilverLudeSi)
check out RPS clutches. friend has a 6 puck sprung hub in his lude. i love driving that car. it grabs like whoa . i will be getting an RPS when i do the swap, i wont be getting the one that can handle 700hp. (he will be going the fully built/boost route) ill be sticking with the "sport series" which also comes in different variations. not sure what hp rating is on that, but they say it handles up to 280ft/lb of tourque.
check em out at http://www.turboclutch.com
[Modified by exaccord, 4:14 PM 5/11/2002]
Old May 11, 2002 | 09:45 PM
CleanCL's Avatar
Mabye the guy rode the **** out of his clutch cause the clutch has no room for play it grabs instantly. My friend has the stage 2 and its works perfect and thats what i am about to buy.
Old May 11, 2002 | 11:21 PM
Prelude Vtec 23's Avatar
Default Re: What clutch are you using? (CleanCL)
clutchmasters stage 4, need a little time to get use too, but grabs hard as hell and I was very pleased w/ it, no regrets
Old May 12, 2002 | 12:32 AM
buh_buh's Avatar
low boost = stage 3
what psi is considered high boost and low boost?
Old May 12, 2002 | 08:19 AM
Quaalude's Avatar
Default Re: What clutch are you using? (buh_buh)
low boost = 8-10 psi
high boost = 12+ psi
Old May 12, 2002 | 02:51 PM
prelude1897's Avatar
ACT with flywheel.....
Old May 13, 2002 | 02:07 PM
Pauls97SH's Avatar
Default Re: What clutch are you using? (prelude1897)
hey do you know if i can use the ACT clutch on a SH,it will work right,and do i really need to get a flywheel with it ,do i have to.And how much should i expect to pay to get the clutch put in? thanks
Old May 13, 2002 | 03:34 PM
JG Luder's Avatar
Default Re: What clutch are you using? (Pauls97SH)
ACT Extreme Pressure Plate (you want to walk funny, get this PP, your left leg will be BUILT) Also, you will probably kick yourself the *** the first time you get stuck in traffic.
The disk is a Clutchmasters stage 3 disk, and the Unorthodox Racing 9lb flywheel.
I bark fourth at the track with this combonation.
dominicanboi215
Feb 22, 2009 07:02 PM
SL0-hatch
May 4, 2006 09:04 AM
ndustryalGSR
Mar 20, 2002 07:11 PM
CivilizedCiv
Jan 25, 2002 07:17 AM
GReddySetGO
Nov 21, 2001 04:26 PM
