92-95 civic spindles the same as 94-01 integra spindles
Old Dec 8, 2006 | 08:17 AM
dc4teg95's Avatar
Default 92-95 civic spindles the same as 94-01 integra spindles
tryin to find out if the spindles from a 92-95 civic r the same as 94-01 integra spindles?
Old Dec 8, 2006 | 08:31 AM
CustomX113's Avatar
Banned
yes i was told they were
Old Dec 8, 2006 | 08:45 AM
dc4teg95's Avatar
Default Re: (95dxb18c1)
anyone confirm this
Old Dec 8, 2006 | 10:22 AM
s2kdre's Avatar
Default Re: (dc4teg95)
yup the same.
Old Dec 8, 2006 | 11:11 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
same, but they may or may not have the threaded holes for the bolts that hold the ABS sensor wire brackets.
Old Dec 8, 2006 | 11:47 AM
Mario_D's Avatar
Default Re: (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">same, but they may or may not have the threaded holes for the bolts that hold the ABS sensor wire brackets.</TD></TR></TABLE>
Yes. They are the same. The will bolt in. I've done it myself on my hatchback.
m-
Old Dec 9, 2006 | 05:55 AM
jduranclk's Avatar
yes it works
Old Dec 9, 2006 | 09:12 AM
CustomX113's Avatar
Banned
yes they will bolt it but you cannot use integra brakes with them.. as i just figured out about 30 min ago....
Old Dec 9, 2006 | 09:18 AM
CustomX113's Avatar
Banned
now if someone can help me out here asap, are civic and integra hubs the same? before i go get the hubs pressed off the civic spindles and press them back on to the integra spindles.... the only problem i had putting the integra brakes on the civic spindles was that the caliper bracket was hitting the rotor
Old Dec 9, 2006 | 09:21 AM
CustomX113's Avatar
Banned
and i probably should mention i have oversized hubs so i cannot use the stock integra hubs
B_Swapped93
Dec 24, 2015 03:02 AM
CustomX113
Dec 9, 2006 09:47 AM
turbo_b16_ex
Oct 26, 2005 01:50 PM
jdmcivicferio
May 8, 2003 09:58 PM
