LS/VTEC Question
Old Dec 8, 2006 | 06:52 AM
jays93eg6's Avatar
Default LS/VTEC Question
I was wondering which piston to use for my set up. I have a set of ITR(P73oo) and a set of P30's. Which of these would be better for my LS block, P72 head with ITR cams and valvetrain. I tried useing the compression calcualtor but with inputing the pistons(either one of them)it said ny compression would be like 12.5:1 and I think that might be alittle more than I want. Oh yea I have a ls rods and gsr rods. How big a diffrence is there in the 2.
Old Dec 8, 2006 | 07:20 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: LS/VTEC Question (jays93eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jays93eg6 &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering which piston to use for my set up. I have a set of ITR(P73oo) and a set of P30's. Which of these would be better for my LS block, P72 head with ITR cams and valvetrain. I tried useing the compression calcualtor but with inputing the pistons(either one of them)it said ny compression would be like 12.5:1 and I think that might be alittle more than I want. Oh yea I have a ls rods and gsr rods. How big a diffrence is there in the 2.</TD></TR></TABLE>
Depends on what compression you want. If its a daily driver and you use pump gas I'd personally would do USDM ITRs P73A0 just b/c its around the 11.9:1 area.
As for the rods, the difference is about 1mm more on GSR rods, but correct me if I'm wrong, but I thought you can't put LS rods onto a GSR crank and vice versa?
Old Dec 8, 2006 | 07:38 AM
jays93eg6's Avatar
Default Re: LS/VTEC Question (SkoundrelUSA)
Well I got both cranks as well. I was kinda leaning towards the LS rods and ls crank. I only have the JDM ITR pistons and JDM B16 pistons. It will not be a daily driver. Its going in a 90 CRX SI. I just want something with a lil more pep than my DOHC ZC that is in there now. I have done plenty of motor swaps, but to be honest this is my first motor build. So I guess I'm a noob .
Old Dec 8, 2006 | 07:43 AM
cute little bastard
Well I'd go for the LS crank/rods because more stroke. And put in the P73s because they yield more compression and also have a flatter dome IIRC.
This setup should have a lot more than a "little pep" over a ZC lol
Old Dec 8, 2006 | 08:22 AM
jays93eg6's Avatar
Thanks man. I was kinda thinking I might get flamed over this q, but hell I searched for 2 days reading up as muh as I could handle and still had no good answer. I think the rex will be kinda quick...
Old Mar 8, 2007 | 07:48 PM
egpwns's Avatar
Jay can you email me egpwns@nycmail.com
I want to pick up the turbo kit and catch can asap...
thanks
young geezer
Oct 12, 2010 08:20 PM
damndude_92
Apr 12, 2009 02:29 PM
girliehonda
Aug 10, 2007 02:05 AM
89EF_Turbo
11
May 20, 2007 07:50 PM
FutureCivic
Dec 11, 2006 12:55 PM
