thermostat!!!
Old Dec 7, 2006 | 09:33 PM
JdM_RACeR07's Avatar
Default thermostat!!!
hey i need to replace my thermostat how do you go about uninstalling and installing a thermostat for a dohc zc it in my 1990 rex so yeah if you have a diagram or sumthin or any info on going about this then that would be great thanks!!!!!!
Old Dec 8, 2006 | 01:11 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: thermostat!!! (JdM_RACeR07)
1)Drain Coolant
2)Undo Thermo housing
3)Remove gasket and thermo
4)Reverse process, make sure to remove all old gasket and that thermo bleed hole is facing up
5)Fill and bleed coolant system
If you want pictures, google "CRX workshop manual" or I believe they have a link to it in the FAQ.
Old Dec 8, 2006 | 01:42 PM
si_zc_civic's Avatar
just get one for an si of the same year. i just got done doing mine an hour ago. its in the bottom hose where it goes into the block
Old Dec 8, 2006 | 01:44 PM
janz3n's Avatar
Default Re: (si_zc_civic)
you have to drain the coolant? thought you could just put the new one in then top up the coolant then bleed.
Old Dec 8, 2006 | 05:15 PM
s10cky's Avatar
draining the coolant isnt a must. but the steps are correct. dont forget to use common sense.
Old Dec 9, 2006 | 12:36 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">you have to drain the coolant? thought you could just put the new one in then top up the coolant then bleed.</TD></TR></TABLE>
This is true, but I always drain/flush any time I open up my cooling system.
lfunk11
Honda Civic (2001 - 2005)
Jan 16, 2012 12:34 AM
stdefhatch
Jul 15, 2007 07:27 AM
george34
May 7, 2006 07:09 AM
hxdrt
17
Jan 21, 2005 11:56 AM
kevin96GSR
Feb 3, 2004 06:41 PM
