so it's been realy cold lately and now when I try to start my car the key won't turn
Old Dec 7, 2006 | 08:59 PM
piggydog's Avatar
Default so it's been realy cold lately and now when I try to start my car the key won't turn
It feels like it's one of those thing where if you jiggle the steering wheel or column it'll turn but it's not that. Can the coldness do something to the ignition?
Old Dec 8, 2006 | 04:40 AM
britishdude's Avatar
Default Re: so it's been realy cold lately and now when I try to start my car the key won't turn (piggydog)
Have you ever had the ignition switch replaced under the Honda recall scheme ? There is a known fault on Prelude ignition switches, Honda dealers will replace with a new switch free of charges if you contact them.
Old Dec 8, 2006 | 07:00 AM
piggydog's Avatar
Default Re: so it's been realy cold lately and now when I try to start my car the key won't turn (britishdud
it's a 92 si. is there a time limit on this recall?
Old Dec 8, 2006 | 08:45 AM
Right : I was thinking of 5th gen, but you could give the dealers a ring to be sure, I can't say for sure if the recall applies to pre 97 cars. But that switch does sound dodgy ? You could try a squirt of WD-40 into the ignition lock while the key is in it, that might lubricate the tumblers in the ignition just enough to get you running.
Old Dec 8, 2006 | 10:31 AM
Jagan'92's Avatar
I squirt wd-40 in there when it gets cold too. My locks also get stiff in the cold.
Old Dec 9, 2006 | 04:25 PM
piggydog's Avatar
tried wd-40 with no luck. Just had to jiggle it for a few minutes everytime which is a pain in the ***. Any other tips?
Old Dec 10, 2006 | 05:24 AM
Sorry pal but having tried the temporary fixes it looks like you need a new ignition switch in there. At least once you get it done that should be the end of the hassle with having to jiggle the key.
Old Dec 10, 2006 | 10:29 AM
92hondalude's Avatar
maybe the new is warn down?
Old Dec 10, 2006 | 05:37 PM
piggydog's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">maybe the new is warn down?</TD></TR></TABLE>
do you mean key is worn down? It works flawlessly in all the doors and trunk.
Old Dec 10, 2006 | 06:46 PM
slamdlude's Avatar
you should take your key and car to a locksmith and have them recut the key back to orginal depths. called cutting it back to code. I used to be a locksmith and would try that before anything. if you can't get the ignition to turn over justt take the key they might be able to do it without the car if they know what they are doing.
djfrankdatank
Sep 23, 2014 09:05 PM
nascar8309
Honda Civic (2001 - 2005)
Nov 19, 2010 06:22 AM
vaporboy12
Aug 29, 2005 07:22 PM
Hazem
15
Dec 16, 2004 01:54 PM
Briman2021
Feb 3, 2004 12:03 PM
