how do i check error codes on a 88 civic
Old Dec 7, 2006 | 08:19 PM
civicracer94's Avatar
Default how do i check error codes on a 88 civic
some one help me out on this.... i dont know much on the obd-0 civic's i knoe there a led on the ecu but what do i do to get it to flash ?
Old Dec 7, 2006 | 08:26 PM
jdm_ef9_b16's Avatar
each quick flash is single digit, he long flash is a 1- , two long flashes 2 and so forth, then look up in your chilton book
Old Dec 7, 2006 | 09:10 PM
GsrTurboCRX88's Avatar
Default Re: how do i check error codes on a 88 civic (civicracer94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer94 &raquo;</TD></TR><TR><TD CLASS="quote">some one help me out on this.... i dont know much on the obd-0 civic's i knoe there a led on the ecu but what do i do to get it to flash ?</TD></TR></TABLE>
If there isnt a flash then there isnt a code. if the cel is on and there is no flash, reset the ecu and see what happens
Old Dec 7, 2006 | 10:41 PM
crxnj's Avatar
Default Re: how do i check error codes on a 88 civic (GsrTurboCRX88)
turn the key to the on position,look at the ecu red light..count the blinks
1 short blink =1 ,,1 long blink = 10..for example 3 short blinks is code 3,,1 long blink and 3 short blinks is code 13..
after you fix the code remove the ecu fuse or disconnect battery for about a min to reset the ecu
Old Dec 7, 2006 | 10:53 PM
Default Re: how do i check error codes on a 88 civic (mr.speaker)
yea i know about the short and long flash's .. so the light comes on by itself ? theres no jumper anywhere ?this is the first obd 0 ihave have ever messed with
Old Dec 7, 2006 | 10:59 PM
no jumper needed
Old Dec 8, 2006 | 12:21 AM
TEXREX88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicracer94 &raquo;</TD></TR><TR><TD CLASS="quote">. so the light comes on by itself ? </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrTurboCRX88 &raquo;</TD></TR><TR><TD CLASS="quote">no jumper needed</TD></TR></TABLE>
When you turn the key far enough to get your electrical gear turned on, the ECU will flash. If more than one code, they will display with a pause in between....That all there is to it.... pretty tight, huh?
Old Dec 8, 2006 | 06:22 PM
Default Re: how do i check error codes on a 88 civic (TEXREX88)
yea i do it on the 5th gen all the time ... but on this car the light dont come on
slowpokecivic
Feb 20, 2007 04:59 PM
BLUE EH3
Jan 12, 2007 01:00 PM
ozzyman
Jan 3, 2006 05:27 PM
ef_you_again
Mar 17, 2005 11:14 PM
raene
May 27, 2001 12:33 AM
