Need help with front mount question
Old Dec 7, 2006 | 06:09 PM
90redintegra's Avatar
Default Need help with front mount question
I bought innovation swap mount kit for b-series. I have 90 hatchback and when I put the motor in the back mount and side mount bolt up but the front mount is like 1 inches off to the right? Am I supposed to change the mount or the crossmember? Also the O2 sensor is hitting the crossmember too? Think the guy before me put in different one or am I missing something?
I did research and couldn't find anything relate to this.
Thanks
Alan
Old Dec 7, 2006 | 06:19 PM
Zaakro's Avatar
Default Re: Need help with front mount question (90redintegra)
you dont use a front mount. so if you really did research you would know this
Old Dec 7, 2006 | 06:31 PM
Default Re: Need help with front mount question (Zaakro)
You kidding me! I did research didn't see anything that says do not need a front mount for that. I knew the swap kit only comes in three but didn't say anything about front mount. Thought it meant for me to use the mount that came in b18. So I just leave that thing out and is that going to be strong enough?
Old Dec 7, 2006 | 10:07 PM
sanimalp's Avatar
$cat /dev/urandom
yes
Old Dec 7, 2006 | 11:24 PM
JT2MA71's Avatar
You can get traction bars with a front mount provision.
Old Dec 7, 2006 | 11:44 PM
CRX 2.0V-T's Avatar
u have to get traction bar to get some clearance. After get the traction bar there no more front mount and lot of space.
Old Dec 8, 2006 | 06:17 AM
Default Re: Need help with front mount question (Lak of Speed)
Awesome man! I am glad I found out that I didn't need front mount before I pull that motor out again! I'll just leave that thing alone and get the traction bar later when I get the turbo kit in it. Thanks for all the help!
Merry Christmas!
civicsiguy21
Apr 10, 2014 04:06 AM
hothotpete
Nov 22, 2004 11:12 PM
