What engine is the Prelude type-s ?
Your in the wrong forum. Try asking in the prelude forum as I'm sure they would know.
Hi, what engine is the Prelude type-s ?
Prelude Type S has 220hp coming from different Pistons, Cams and a slightly different ECU. Ashame we get left out of the better things here!
Is the Prelude Type-S the same Prelude SH here in USA?
the SH has ATTS, along with a few minor visual differences and additional features, the SH has the H22A4.
The Prelude Type S also has several structural reinforcements to the unibody itself that normal Preludes do not have (again similar to the ITR). It also has a upper strut tower bar standard. It has no moonroof and no radio in addition to other weight savings. It comes standard with a front chin spoiler, rear decklid spoiler, and body-keyed rocker trim.
Andrew
About prelude type-s piston set, what bore and height comparing to B18C5, 11.1 cr pistons ?
Thanks,
Pinota
Thanks,
Pinota
Andrew
I have to correct you on that there is a prelude motor that that is higher then the Type S i want to say its called the SR but dont Quote me the name, it comes with 240 HP.
The SR if i am not mistaken was the canadain verson of the h23!!
Evan the 2.3 vtec that the UK and japan gets only puts out 220ps!!
could he be thinking of the Sir? I think it's the lesser JDM version of the Prelude. As far as I have always heard and read the Type S is King.
Type-S is the top of the line Stock H22a....240hp? Maybe you're thinking S2000? check jdmhondaparts.com type-s is the big boy..
No need to get angry, I'm just saying there will be alot of people really surpised if you can actually find this motor.
The 2.3L Accord DOHC VTEC engine is rare...but it's not 240hp...
