22X8X15 for mostly stock GSR??
Old Dec 7, 2006 | 02:47 PM
Project_EK's Avatar
Default 22X8X15 for mostly stock GSR??
what up..
are 22X8X15 overkill for a bolt-on's GSR in a hatch, i just dont wanna have a problem heating them up!?? n also u think ill be okay with the stock GSR tranny??
is anyone running this setup??
Old Dec 7, 2006 | 03:46 PM
dustin528's Avatar
Default Re: 22X8X15 for mostly stock GSR?? (Project_EK)
Should work fine. I have 23x7.5x15 for mind, and i have no problem heating them up at all. I normally do 2nd gear burnouts with hardly any water.
Old Dec 7, 2006 | 04:22 PM
FORCE_FED's Avatar
i used 22x8x13 on my civic with b20vtec with bolt ons and worked fine. was averaging about 1.8 60ft times. have to get bigger wheels and slicks because of turbo.
Old Dec 8, 2006 | 05:01 AM
Jason703Racing's Avatar
Default Re: 22X8X15 for mostly stock GSR?? (FORCE_FED)
id go 22x9x13
Old Dec 8, 2006 | 07:25 AM
skunked's Avatar
Default Re: 22X8X15 for mostly stock GSR?? (Black00em1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black00em1 &raquo;</TD></TR><TR><TD CLASS="quote">id go 22x9x13 </TD></TR></TABLE>
no need to go that wide with a stock motor.
Even 20" slicks on some 14" steel rims will work pretty good for his application.
Old Dec 8, 2006 | 07:56 AM
4piston's Avatar
Default Re: 22X8X15 for mostly stock GSR?? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Even 20" slicks on some 14" steel rims will work pretty good for his application.</TD></TR></TABLE>
Ditto. Do yourself a favor and run a 20 inch MT. A 22 is overkill for your power level...especially with a GSR trans. About 200 years ago I tried 22s on my 170whp 1.8 and it killed my times by 3 tenths compared to my 20s. Third gear was long!
Old Dec 8, 2006 | 07:59 AM
1 2 NV's Avatar
20s for sure since you say its an almost stock motor.
Old Dec 8, 2006 | 08:49 AM
Project_EK's Avatar
thanks ppl..
Old Dec 12, 2006 | 10:16 PM
darrinbrewer's Avatar
Default Re: (Project_EK)
i ran 20x8x14 mickey's on my 4dr gsr when i had ITR cams and and CTR tranny.
i still currently run them on my built gsr motor in a hatch, run 2.0 60's on a non-prepped track. 13.51@99mph ..about 7500rpm in 4th
Old Dec 13, 2006 | 05:26 AM
JDMisGOOD's Avatar
Default Re: (darrinbrewer)
20's and proper pressure should do the trick for a stock engine
Old Dec 13, 2006 | 10:51 AM
Default Re: (JDMisGOOD)
im selling a set of m&h's 22x9x13's. let me know. 150 there pretty much brand new, just a couple passes on them not alot. ALOT of meat left.
dunkd
Feb 1, 2006 10:04 AM
97dc2
Dec 24, 2004 03:41 PM
sp00led
Apr 2, 2004 03:01 AM
F00LI0
Jul 18, 2003 09:46 AM
Livin4Him
May 29, 2003 07:15 AM
