I need spec's on how to cut b-series shift linkage
It depends on what mount kit you are using!
Here is a link showing how I did it;
http://www.performanceforum.co....html
Wes
Wes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ »</TD></TR><TR><TD CLASS="quote">people still do this? </TD></TR></TABLE>
Yeap.
Yeap.
I have a 91 si with b-series in it but i need to cut the shift linkage just like the jdm si-r,so it bolt up clean.
i had the same problem , quickest thing to do is cut both bars then roughly hook them up then now ur will have a gap get someone to hold the shifter in the car stright then messure the gap. once u get that messurement get a peice of metal o round pipe works best to slid over the shift bars once u get the position spot weld it so u dun lose the proper length take out the shift bars and give it a good weld.
Thats wat i did and never had a problem with it still going on strong.. hope that helps u out if u dun wanna spend the buck to get the ones made for ur car ....
if you can weld why not? its not hard
1. Cut B series linkages in half
2. Mount both end to the tranny, the others to the car.
3. Measure, cut again and weld together.
Or
Spend 100$ and get a premade shiftlinkage that isn't haggard as ****, like I did.
Or
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv »</TD></TR><TR><TD CLASS="quote">1. Cut B series linkages in half
Or
Spend 100$ and get a premade shiftlinkage that isn't haggard as ****, like I did.</TD></TR></TABLE>
lol. If you know what you're doing, a cut and welded DA linkage is not 'haggard'. For a long time, most of those "premade" shiftlinkages were just cut and welded by someone else, and marked up $80.
Or
Joecivic94
Feb 17, 2008 05:28 AM
