Engine work - Give me something to do
97 accord 4dr EX Vtec.
just got a new car last week so im really pumped about it and I was wondering if anyone knew any fixes, cleaning, tweaks, or maintanence necesseties i could do myself. anything would be appreciated.
97? Hoses and all rubber tubes are pretty worn. Get a manual, and strip off all the main cooling hoses,every hose that carries water, and flush the system out good. Replace the t-stat.
Replace all the rubber smog-lines. Replace the belts. If it's rubber, and 8 years old, it's getting old and soft. This stuff will keep you busy, and will go a long way towards saving the engine from a possible overheat.
Check the tranney fluid condition, dump if needed. If dirty, completly bleed the brake system out and replace the fluid. Now you're busy. Wrenchy
valve adjust, fuel system clean, tranny drain and fill. oil change. air filter. plugs, wires, cap, rotor, tire pressure, fart can.
NightHawk92
15
Jul 16, 2014 08:41 PM
