Hot start problem(searched)
Old Dec 7, 2006 | 02:35 AM
90_civic_Si's Avatar
Default Hot start problem(searched)
I`ve searched and never really found a good answer, just replace something and try it out.
My car will start right up in the morning like as soon as you turn the key, bang it will fire up. I`ll drive to get coffee come back out and roll over, roll over then start. Sometimes when warm it will roll over catch then die, then try it again it stumble then starts. What i want to know is what starts working when the car is warm cause that`s what has to be causing this problem.
Old Dec 7, 2006 | 02:36 AM
1989CivicSi's Avatar
Default Re: Hot start problem(searched) (90_civic_Si)
Check the main relay?
Old Dec 7, 2006 | 02:55 AM
Default Re: Hot start problem(searched) (1989CivicSi)
Will do, thats one thing i haven`t checked.
Old Dec 7, 2006 | 07:56 AM
Checked the relay at lunch and it`s working fine. Took it right out hooked it to my battery and check the pins for continuity and the tester blinked on every pin that it was supposted to so and other suggestions.
Old Dec 7, 2006 | 08:07 AM
89cmutr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1989CivicSi &raquo;</TD></TR><TR><TD CLASS="quote">Check the main relay? </TD></TR></TABLE>
He's right this will cause the problem you are having. Also it wont be a continuity problem until the relay green (brown) board warps and loosen connection due to heat. Bad soilder joints on the board. Pull it out and leave the cover off while driving and see if cures the problem or junkyard main relay to test.
Old Dec 7, 2006 | 11:56 AM
Default Re: Hot start problem(searched) (89cmutr)
I`m already looking for a spare one to try, but i`ll take the cover off and try that, thanks.
benwadb1
Sep 14, 2008 05:31 PM
JDM_rolex
Aug 14, 2006 09:30 AM
g-ride-si
Jan 13, 2006 08:14 AM
esracer
Jun 25, 2005 08:08 PM
jdmkrazie
Jun 16, 2004 08:42 AM
