rattling sound at around 3k -3.5k rpm, what's ur suspect?
Old Dec 7, 2006 | 01:01 AM
llozll's Avatar
Default rattling sound at around 3k -3.5k rpm, what's ur suspect?
could it be heat shield?
or exhaust manifold?
i've searched but i ended up to those two questions above,
if someone can tell any'bout it will be appreciated,
thanks,
O J
Old Dec 7, 2006 | 01:06 AM
PrinceAli132's Avatar
Default Re: rattling sound at around 3k -3.5k rpm, what's ur suspect? (llozll)
Most likely your cat heatshield, just get under the car and check them out. And sometimes it could just be a couple rocks got trapped in between and are rattling around. If its the heatshild you can just remove them.
Ali
Old Dec 7, 2006 | 01:16 AM
ILoveJDM.'s Avatar
I have never heard an Integra that doesnt rattle... Maybe its just me though!
Old Dec 7, 2006 | 04:48 AM
del sol1658's Avatar
Default Re: (ILoveJDM.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILoveJDM. &raquo;</TD></TR><TR><TD CLASS="quote">I have never heard an Integra that doesnt rattle... Maybe its just me though!</TD></TR></TABLE>
This guy speaks the truth.
My brothers dc2 does nothing but rattle.
Old Dec 7, 2006 | 06:15 AM
gsrclan's Avatar
Could be the A pipe.
Old Dec 7, 2006 | 03:20 PM
ILoveJDM.'s Avatar
Lol, not totally rattle always, but vibrate constantly!
Old Dec 7, 2006 | 03:36 PM
silentdeath12886's Avatar
before my exhaust install i realized my stock heatshield on my cat was held on by 1 weld point out of the 4.
Old Dec 7, 2006 | 03:47 PM
Fat Chick Magnet's Avatar
mine was from my headers. theres a heat sheild on the front of the header and one behind it. the one behind it is a bitch to get out you have to take the whole headers out to take it off. after i purchased new headers the sound went away.
Old Dec 7, 2006 | 07:09 PM
99Geeezer's Avatar
is your exhaust manifold stock. my stock manifold was rattling because it id double walled and the weld broke internally and would rattle at certain rpms. it was impossible to weld so replace it with a dc header(considered stock replacement part).
Old Dec 7, 2006 | 07:36 PM
BoltonGSR's Avatar
Default Re: rattling sound at around 3k -3.5k rpm, what's ur suspect? (99Geeezer)
I had this problem once, at only certain rpm like that. I took half of the heat shield off the cat and bolted down only the top half... it stopped...
Old Dec 7, 2006 | 07:39 PM
slooogsr's Avatar
I also had this problem, if you have an older aftermarket exhaust like DCSports it could be the resonator as well as the muffler packing inside..........
more than likely its a heatshield........
Old Dec 7, 2006 | 10:10 PM
1998_4dr_gsr's Avatar
Default Re: (slooogsr)
I have the same problem, that's why i bought the dc header. Stock manifold
Old Dec 8, 2006 | 10:09 AM
NAmodified's Avatar
Default Re: (1998_4dr_gsr)
my dam heat shield rattles around 3-4k and stops, so it might be ur heatshield
ek9.5
10
Aug 12, 2007 05:06 PM
tgreene2098
Jul 20, 2007 08:22 PM
Azn Kenny
Nov 13, 2005 02:09 PM
Toadfart
Dec 18, 2003 01:48 AM
J.A.SBTCC
Apr 13, 2003 11:59 PM
