my car wont rev past 5000rpm's
Re: my car wont rev past 5000rpm's (ek9.5)
Does it sound like the rev limiter is kicking in? Or does it just sound like it is out of power? If it is the latter check your exhaust to make sure you have a lot coming out, it could be that your CAT broke apart and is obstructing the exhaust flow....just one of many possibilities.
cheers
cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9.5 »</TD></TR><TR><TD CLASS="quote">it stays at 5000 redlining and when it hits 3500 rpms the cat dose a wierd sound</TD></TR></TABLE>
If it is at 5000 it is not redlining.
Check to see if you do have a good exhaust flow out the tail pipe. If you don't you can try to get a friend to rev it up to 3500 and then start lightly hitting the CAT to see if it makes a difference. Either way to push it, if it is a broken/clogged cat you can easily crack a header or blow the header gasket due to the high pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9.5 »</TD></TR><TR><TD CLASS="quote">it bouces like a rev limiter</TD></TR></TABLE>
Then it is most likely not the cat
spicoli
12
12-20-2004 11:57 AM
jfingers
06-28-2004 07:19 PM
Nextelbuddy
14
05-16-2003 09:31 AM
