93,16deg,12:1
Old Dec 6, 2006 | 10:25 PM
MotorSpecies ver1.6's Avatar
From: MoonSHINE Metropolis, .FL. Run Free, North America
Default 93,16deg,12:1
Given a 12.0:1 compression ratio and 93 octane, will 16deg. timing be alright to where the motor doesn't knock?
Thanks
Old Dec 6, 2006 | 11:57 PM
92TypeR's Avatar
FSAE
Default Re: 93,16deg,12:1 (xtrada ver1.6)
Your base timing has little to do with how your engine will react under load, it is simply just that, a base. You can run 10 degrees at the distributor and still get detonation if your ignition tables are tuned improperly.
For instance, I am running 28.5deg timing at 9400 rpms at WOT, but only 10 degrees at 2000 rpms at WOT.
FWIW I am running 15 degrees at the distributor with my 12:1 2.0L.
Old Dec 7, 2006 | 11:37 AM
d16dcoe45's Avatar
Default Re: 93,16deg,12:1 (92TypeR)
Kind of related--but does anyone know what the actual total timing is on a stock jdm b18 type r motor? Or a usdm? How about full throttle timing at say 3000 rpm?
allnaturalb16
21
Aug 14, 2007 08:57 PM
LSTEG96
Sep 12, 2005 12:40 PM
98slvrcx
Jul 28, 2002 09:58 PM
Tx92AccordExD
Jul 22, 2002 11:13 PM
macdaddy
Apr 30, 2002 07:56 AM
