Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
good way to get paint scuff off car?
Old Dec 6, 2006 | 09:51 PM
spoonlongblock's Avatar
Default good way to get paint scuff off car?
some idiot parked near me at work and scuffed my passenger's side door with white paint, its not bad but need a good buffing compound as I will be removing it by hand.
Old Dec 7, 2006 | 02:16 AM
Demonis's Avatar
that happend to me and all polishing compound did is remove my clearcoat in the area and further scratch my car.
Old Dec 7, 2006 | 02:49 AM
Type X's Avatar
Default Re: good way to get paint scuff off car? (spoonlongblock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonlongblock &raquo;</TD></TR><TR><TD CLASS="quote">some idiot parked near me at work and scuffed my passenger's side door with white paint, its not bad but need a good buffing compound as I will be removing it by hand. </TD></TR></TABLE>
try rubbing compound
and follow with wax
Old Dec 7, 2006 | 06:40 AM
CoryB's Avatar
Get some Meguiars Scratch-X and give that a try. It's a mild polishing compound and will probably take several passes to make much difference, but you'd have a hard time damaging the paint with it.
Old Dec 7, 2006 | 06:49 AM
TRE_'s Avatar
Default Re: (CoryB)
I've used scratch -X and personally i think it sucks... try a light cutting compound and if that doesnt work use a higher intesity cut ...
heres the mild compound (tan bottle) that works best when applied w/ a buffer...
[IMG][/IMG]
Old Dec 7, 2006 | 09:31 AM
Default Re: good way to get paint scuff off car? (Type X)
the rubbing compound worked great, I used 3m rubbing compound and then waxed with meguirs cleaner wax thanks
Old Dec 7, 2006 | 09:46 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonlongblock &raquo;</TD></TR><TR><TD CLASS="quote">the rubbing compound worked great, I used 3m rubbing compound and then waxed with meguirs cleaner wax thanks</TD></TR></TABLE>
Civic05'
Paint and Body
22
Apr 26, 2014 06:37 AM
omehegan
Paint and Body
Oct 20, 2007 07:28 PM
khmerxnuttyxb
Paint and Body
Oct 17, 2007 08:47 AM
menkio
Aug 20, 2004 10:43 AM
sjteg
May 13, 2003 10:48 AM
