Piece it together
Old Dec 6, 2006 | 07:32 PM
hazzardboy95's Avatar
Default Piece it together
Hey whats up again. Im thinking about stepping up the integra. Right now its an almost stock ls non vtec. Im thinking about tecin it. I would **** a flame if i could find a itr head to sit on top of that block. Although the b16 and the gsr are more common i would like to step it up alittle bit more. To give you a run down the motor was rebuilt. It had 160k miles on it then the block was sleeved and re honed while the head was decked, the valve guides replaced and the valves and seats were re cut. Now it only has about 6k miles on it and i deffinately think it could take the high rev capability of the type r head along with the added compression. I looking for some of your opinions because i am a leaf in the wind right now i could blow in any direction.
Old Dec 6, 2006 | 07:51 PM
DS002's Avatar
Banned
Default Re: Piece it together (hazzardboy95)
if you have sleeves boost the mother ****** , expletive vtec .
Old Dec 6, 2006 | 07:55 PM
be18see1's Avatar
Default Re: Piece it together (DS002)
n/a vtec ftw. down with turbos.
Old Dec 6, 2006 | 07:56 PM
im thinking of staying all motor though, at least for right now. I ahev never owned a vtec car and im jonesin for one, but not just anyone. One that i built that i can run the ***** off of and not worry about over boosting on accident. I would do that cause i dont know when enough is enough. if i pulled up next to you in a turbo car and thought i might loose i would jack the boost up and blow it sky high. Im not mature enough yet. sorry. any other ideas
Old Dec 6, 2006 | 07:59 PM
DS002's Avatar
Banned
Default Re: Piece it together (be18see1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">n/a vtec ftw. down with turbos.</TD></TR></TABLE>
Yea if you like spending 5 grand to see 200 whp and less torque than a golfcart makes
Anyways OP if you insist on staying N/A just get a B16 head and swap the cams , mill a bit off the deck to increase compression or get different pistons to bump up the compression . And dont forget to tune , tuning is the key to making power .
Old Dec 6, 2006 | 08:05 PM
you think i should just use the b16 head with the itr internals and cams
Old Dec 6, 2006 | 08:06 PM
VTteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazzardboy95 &raquo;</TD></TR><TR><TD CLASS="quote">I would **** a flame if i could find a itr head to sit on top of that block </TD></TR></TABLE>
First time I've ever heard someone say that.
Old Dec 6, 2006 | 08:26 PM
DS002's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hazzardboy95 &raquo;</TD></TR><TR><TD CLASS="quote">you think i should just use the b16 head with the itr internals and cams</TD></TR></TABLE>
Yes sir , if you want some real power look into things like ITB's (individual throttle bodies) or a better intake manifold , ported throttle body , and 4-1 header with a 2.5" collector , high flow cat and exhaust , and upgrade your cams and valvetrain . And like i said before TUNING TUNING TUNING !!!
KPDSM
Oct 30, 2013 01:13 PM
Bender C/F
Engine Management and Tuning
Jun 28, 2009 08:13 AM
swappedcx
Sep 4, 2006 05:10 AM
poorman's type-r
Jul 28, 2006 04:10 PM
Pre1ude
Sep 20, 2004 12:57 PM
