using mad break fluid???
Old Dec 6, 2006 | 06:14 PM
Scotland:EF3's Avatar
Default using mad break fluid???
every couple days im buying brake fluid and i cant find where im leaking from, not the master, any thoughts?
Old Dec 6, 2006 | 06:16 PM
Crx Jimmy's Avatar
Default Re: using mad break fluid??? (88EF9)
if you have rear drums look at the wheel cylinders
Old Dec 6, 2006 | 06:22 PM
i think im leaking from the front though, cause its all over inside the fender lining, but will check that thanks!
Old Dec 6, 2006 | 06:36 PM
Hamstr323's Avatar
Default Re: (88EF9)
could be front calipers or one of your lines is broken/cracked it happend to me a while back
Old Dec 6, 2006 | 06:57 PM
Crx Jimmy's Avatar
Default Re: (88EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 &raquo;</TD></TR><TR><TD CLASS="quote">i think im leaking from the front though, cause its all over inside the fender lining, but will check that thanks!</TD></TR></TABLE>
If its on the fender liner its either leaking from the master itself and dripping down or more likely your hose has a small pin hole in it. the stock rubber is 2 layered for safety it might be seeping through and under hard breaking it squirts out but you should notice the pedal being soft. check the bleeders in the calipers too
Old Dec 6, 2006 | 07:01 PM
checked the bleed valve its on tight, any way to test the lines?
Old Dec 6, 2006 | 07:41 PM
hybrid1990crx's Avatar
Default Re: (88EF9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88EF9 &raquo;</TD></TR><TR><TD CLASS="quote">checked the bleed valve its on tight, any way to test the lines?</TD></TR></TABLE>
have a friend press on the brakes. look at the lines and calipers with your eyes.
Old Dec 6, 2006 | 09:57 PM
supracrx's Avatar
if its leaking that bad u should feel a low pedal...
Old Dec 7, 2006 | 07:23 AM
dynamitezz's Avatar
Default Re: (supracrx)
I had this problem, but it was just a leaky cylinder in the drum break, but I would definetly have a friend push breaks while on jack stands or something with tire off and take a look yourself, Post pics when u figure it out!
Old Dec 7, 2006 | 05:21 PM
Default Re: (dynamitezz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dynamitezz &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem, but it was just a leaky cylinder in the drum break, but I would definetly have a friend push breaks while on jack stands or something with tire off and take a look yourself, Post pics when u figure it out!</TD></TR></TABLE>
Not trying to say you are wrong, but from the o/p I just want to make this clear. DON'T press the brake pedal with the drums off, theres a good chance the pistons could pop out of the wheel cylinder. To check them all you have to do is squeeze the rubber gromets with your fingers to see if fluid comes out.
Old Dec 13, 2006 | 08:30 PM
i have a hole in my break line.
Old Dec 14, 2006 | 06:01 PM
Default Re: (88EF9)
ok. replace it.
Old Dec 14, 2006 | 07:20 PM
RockWolf's Avatar
Default Re: (hybrid1990crx)
or a trick my dad used to close a big hole in the brake line...use a solder iron if its for a small hole ..works like a charm!!! just try not fill it but do a cover..
Old Dec 14, 2006 | 08:30 PM
RockinthEFhatch's Avatar
Pepboys sells this neon **** that show's leaks when put into the brake resevoir.
eh9deux
17
Jun 13, 2011 07:33 AM
DC5_lov3r
Feb 28, 2009 07:42 PM
wolfmann
May 18, 2007 08:55 PM
slipperyduck
Apr 4, 2004 11:35 AM
py1188
Apr 27, 2003 04:41 PM
