brake Lights stay on all the time. Need help find out the problem.
Old Dec 6, 2006 | 05:29 PM
julio_bOostamante's Avatar
I'm a Jackass
Default brake Lights stay on all the time. Need help find out the problem.
So the brake lights stay on all the time the only way to make them go off is to disconnect them at the back in the trunk. WOuld this be due to a relay or the brake switch on the pedal assembly? anyone have this problem b4?
thanks!
Julio
BTW this is on a new 4 door i juxt bought. SO i now own 2 4 door EFs. A 88 and a 90 . Woot!
Old Dec 6, 2006 | 05:39 PM
omgwtfbbqcrx's Avatar
on my crx usually the brake lights stay on always, and go off when i press the brakes, right before the brake light switch goes out, did you check that?
Old Dec 6, 2006 | 05:49 PM
I'm a Jackass
Default Re: (omgwtfbbqcrx)
i will go and look at the brake light switch in a minute. But since i just bought the car i havent had much time to check it out. Gimme 10 minutes ill let you know if i see a problem with the brake switch.
Old Dec 6, 2006 | 06:11 PM
I'm a Jackass
Default Re: (julio_bOostamante)
yeah it was the black rubber thingy on the brake pedal... nice!
Old Dec 7, 2006 | 04:46 PM
Old Dec 7, 2006 | 05:04 PM
STDClayton's Avatar
sometimes it can be using an improper bulb in the socket
(ex.: a bulb with one lead contact in a socket that has two lead contacts)
other times still it can be that the fillaments are touching in a dual fillament bulb causing the electrical current to not complete the circuit, but instead to flow back from where it came
(ex.: your gauge cluster and parking lights [1st click on the light switch] coming on when pressing the brakes)
ihonda
21
May 31, 2012 09:53 AM
EGKevin209
Jun 22, 2010 12:41 PM
guero2craze
Jul 28, 2008 05:30 PM
musclehead954
Feb 27, 2008 10:28 AM
esca
Aug 30, 2004 01:31 PM
