ITR front sway bar on my 96 DX
Old Dec 6, 2006 | 04:36 PM
timmy0tool's Avatar
Default ITR front sway bar on my 96 DX
i just recently installed an ITR front sway bar on my 96 DX coupe and i noticed it hangs very low under the frame. it looks like it can get snagged if something is sticking out of the ground. i looks like two u-loops.
i know i installed it correctly (or did i?) and it functions correctly too. i was just wondering why it hangs so low ?!
EDIT! pics up! everything works fine, no rubbing, no problems other than a lower ground clearance .
Modified by timmy0tool at 9:33 AM 12/18/2006
Old Dec 6, 2006 | 04:53 PM
MidwestSiR's Avatar
....?? what front lca arms are you using?!
Old Dec 6, 2006 | 04:57 PM
Heylookits shawn's Avatar
Default Re: (MidwestSiR)
you may have installed it incorrectlly, because its supposed to go above the exhaust, not droop down.
Old Dec 6, 2006 | 05:04 PM
MidwestSiR's Avatar
Default Re: (Heylookits shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">you may have installed it incorrectlly, because its supposed to go above the exhaust, not droop down.</TD></TR></TABLE>
true story
still wanna know what arms you're using
Old Dec 6, 2006 | 05:50 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">you may have installed it incorrectlly, because its supposed to go above the exhaust, not droop down.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">true story
still wanna know what arms you're using </TD></TR></TABLE>
come on guys he said FRONT
Old Dec 6, 2006 | 05:51 PM
blinx9900's Avatar
Default Re: (blinx9900)
can you even put an itr front bar on an ek? i though your supposed to use 99-00usde si or CTR...
Old Dec 6, 2006 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">come on guys he said FRONT</TD></TR></TABLE>
have you been under a car? regardless of front or rear the swaybar does not hang lower than the exhaust.
i was under the impression all ek's had a stock front sway? i have an em1, so i dont know about the lower trim levels
Old Dec 6, 2006 | 06:04 PM
MidwestSiR's Avatar
dumbest thing i heard today
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">can you even put an itr front bar on an ek? i though your supposed to use 99-00usde si or CTR...</TD></TR></TABLE>
that's what we're trying to figure out here guy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">??
i was under the impression all ek's had a stock front sway? i have an em1, so i dont know about the lower trim levels</TD></TR></TABLE>
dx's and i think cx's didn't have front bars nor arms to mount them. you need either HX/EX front arms or Si/CTR front arms
HX/EX bars mount differently than Si/CTR
i'm sure the itr bar will fit si/ctr arms.. just now 100%
Old Dec 6, 2006 | 06:07 PM
i'm sure the itr bar will fit si/ctr arms.. just now 100% </TD></TR></TABLE>
i see. i was going to type more right now but the smell of pizza wafted in to my room, im going downstairs to eat. will try to help more later
MidwestSiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heylookits shawn &raquo;</TD></TR><TR><TD CLASS="quote">i see. i was going to type more right now but the smell of pizza wafted in to my room, im going downstairs to eat. will try to help more later </TD></TR></TABLE>
haha.. enjoy
Old Dec 6, 2006 | 08:35 PM
BlueIntegraBoy's Avatar
Default Re: ITR front sway bar on my 96 DX (timmy0tool)
My GSR/ITR front sway is almost flush with the bottom of my car.
Old Dec 6, 2006 | 08:40 PM
blinx9900's Avatar
no they dont all have sway bars... yes ive been under a car, it sounded like midwestsir was referring to the muffler section location in refrence to the sway bar... my bad...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">dumbest thing i heard today
glad i could be of service
Old Dec 6, 2006 | 08:57 PM
instrument's Avatar
can a sway bar be installed "upside down"?
its the only way i could picture it being low enough to "snag" something..... but i couldn't imagine someone actually doing it..
i hope you admit to whatever you may have done....
Old Dec 6, 2006 | 09:18 PM
spock_rocker's Avatar
memoryFAB.com representative
Default Re: (instrument)
im hoping he's using a subframe kit! i think we all know how weak the 96-00 subframes are. and the 96 DX LCAs came w/ holes for the endlinks
Old Dec 6, 2006 | 09:27 PM
Default Re: (spock_rocker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spock_rocker &raquo;</TD></TR><TR><TD CLASS="quote">im hoping he's using a subframe kit! i think we all know how weak the 96-00 subframes are. and the 96 DX LCAs came w/ holes for the endlinks</TD></TR></TABLE>
Dude, can you read the title? F-R-O-N-T
Old Dec 6, 2006 | 09:51 PM
EK k kay's Avatar
Default Re: (BlueIntegraBoy)
You need to run EX front lca's (Si/CTR will NOT work because of the way their bars are mounted). Your DX did not come with a factory front sway bar and your stock front lca's do not have the mounting holes. Your sway bar hangs real low because you haven't bolted the endlinks to the lca's.
http://www.jdmuniverse.com/for...ybars
Old Dec 6, 2006 | 11:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Dude, can you read the title? F-R-O-N-T</TD></TR></TABLE>
Old Dec 7, 2006 | 12:22 AM
Haha. Who comes up with these?
Old Dec 7, 2006 | 05:54 AM
monicle's Avatar
Im holding out for pictures.
Old Dec 7, 2006 | 06:01 AM
MidwestSiR's Avatar
or a reply... or something...
Old Dec 7, 2006 | 06:03 AM
Blk00EJ8's Avatar
Yea, it's supposed to curve up into your subframe towards the front of where your center shift console is, above the exhaust and above the shift linkage.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instrument &raquo;</TD></TR><TR><TD CLASS="quote">i hope you admit to whatever you may have done....</TD></TR></TABLE>
hahahaha
Old Dec 7, 2006 | 09:58 AM
timmy0tool's Avatar
dang fellas here's the skinny.
i'm using an ITR front sway bar with ITR lower control arms. i just used the half of the lca that has the hole for the endlink. the rest (i.e. bushings, brackets, portion that the balljoint attaches to) are all DX parts!
i'm sure they are installed correctly, and over the exhaust/shift linkage. it just swings pretty low, which is the main topic of this thread kids.
i'm sure pics will clear everything so i'll get some ASAP! hang tight!
Old Dec 7, 2006 | 10:13 AM
blinx9900's Avatar
Default Re: (timmy0tool)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy0tool &raquo;</TD></TR><TR><TD CLASS="quote">i'm sure pics will clear everything so i'll get some ASAP! hang tight!</TD></TR></TABLE>
good idea
Turbo B18C EJ6
Suspension & Brakes
May 31, 2010 11:24 AM
TKAUTOMOTIVE
Oct 19, 2008 09:24 PM
timmy0tool
13
Dec 18, 2006 10:06 PM
MBDiagMan
Oct 27, 2004 11:12 AM
Fez
Apr 2, 2003 04:18 PM
