buying a gsr teg tomorrow HELP ASAP PLEASE
the car seems like it boggs down when it hits vtec and the tach goes crazy what do you guys think it could be or well it messes up around 5k rpms not sure were it is supposed to hit totaled my ls teg monday and buying this one so dont have much knowledge bout vtec
I wouldn't rush into buying it with that problem. Are you buying from a dealer or private seller? You can buy a properly working GSR for about the same or a little more, depending on mileage and year if you search a little bit longer.
mine was doing that .. does it do it when you press on the gas gently or just when you gas it hard .. mine was only when i gas it hard .. changed spark plugs wires dist cap and rotor and msd blaster coil .. runs like a top now
