how to open a trunk to a '93 del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.newdelsol »</TD></TR><TR><TD CLASS="quote">No latch, no key barrel </TD></TR></TABLE>
Then what is keeping it closed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr.newdelsol »</TD></TR><TR><TD CLASS="quote">someone messes up the lock when they tried to break into it and pushed in the lock in. what else can i do???</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreyDel »</TD></TR><TR><TD CLASS="quote">get a key cut from honda using your VIN number and ID </TD></TR></TABLE>
crowbar...
nawwe dont do that
crowbar...
nawwe dont do that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bfreeman »</TD></TR><TR><TD CLASS="quote">
crowbar...
nawwe dont do that </TD></TR></TABLE>
That's what he's going to have to do unless he can find the cable and pull it with a pair of needle nose or something...
Pry that bitch up.
Sux, but oh well, 'tis is life.
EDIT:
PS: You can try drilling it..but you don't know how well it's fucked up...I'd drill and cut the latch out...it'd be pretty fucked up either way...
Sorry.
crowbar...
nawwe dont do that </TD></TR></TABLE>That's what he's going to have to do unless he can find the cable and pull it with a pair of needle nose or something...
Pry that bitch up.
EDIT:
Sorry.
im confused.. on your 2nd post you side "not the trunk latch, but the drivers side latch"
Do you mean the drivers side door doesnt open because the lock is messed up from someone braking in? Why not just open the passenger door, get in, and then open your door from the inside and figure it out from there? If your trunk lock is messed up i dont really know what to tell you short of drilling it out and pretty much destroying your trunk lid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman1320 »</TD></TR><TR><TD CLASS="quote">Bust ur passenger side taillight out, I had 2 do it... put ur right arm in the trunk...grab the rod and presto...trunks open!!!</TD></TR></TABLE> LMAO!!
that's cheaper then a trunk lid. my lid was already damaged from thieves, so i made a sardine can out of it.
hahahahahaha
Good luck
hahahahahaha
Good luck
is there any way you can get inside the trunk through the cabin? my ej1 has a lock for the backseat to lower (above the backseat). if you can do that, you should be able to rip some trim away from the latch and figure out the rod/latch situation. if you can't get through, i'd say take hondaman 1320's advice lol. hey, i guess it's been done
LMFAO.....LOL....I work at a local police dept. I am sitting here and read this and busted out laughin...a bunch of ****** cops are staring at me now.
TatDc5
13
Jun 25, 2008 09:11 AM
ITSTOCK
17
Jan 29, 2004 02:22 PM
