roller rocker setup
Old May 10, 2002 | 02:04 PM
vspec12's Avatar
New User
Default roller rocker setup
does anyone know who make a roller rocker setup for a b series head?
Old May 10, 2002 | 02:05 PM
Mikey3000's Avatar
Default Re: roller rocker setup (vspec12)
Ferrea?
Old May 10, 2002 | 06:14 PM
carolinaACCORD's Avatar
yes ferrea makes them, but i believe it does away with vtec function,
then again i might just be too drunk to know right know........i mean now.
Old May 10, 2002 | 07:40 PM
b19coupe's Avatar
Default Re: roller rocker setup (carolinaACCLUDE)
Crane makes some, but I don't know how good they are.
http://www.cranecams.com/import/acuracams.htm
I have not seen any dyno numbers on this stuff either.
Old May 10, 2002 | 08:47 PM
earl's Avatar
Default Re: roller rocker setup (b19coupe)
You can't use the roller rockers without a custom ground roller cam. Rollers change spec of any cam.
Old May 10, 2002 | 10:00 PM
Rocket's Avatar
Default Re: roller rocker setup (earl)
The roller rocker has a smaller arc and thus a lower ratio the stock rockers so the roller cam has to be considerably bigger than the stock style cams.
Old May 11, 2002 | 05:46 PM
earl's Avatar
Default Re: roller rocker setup (Rocket)
The different size arcs change the cam opening and closing dynamic but the actual rocker ratio is set by the manufacturer of the rocker. I don't think there would be room to fit "considerably bigger" cam lobes in a b series head.
Old May 11, 2002 | 09:25 PM
Rocket's Avatar
On the B series Vtec heads the rocker manufacturer can't change the ratio much since the rocker geometry is dictated by the location of the rocker shaft and the location of the cam which are both fixed on these heads.
Any roller with an arc size close to the size of the stock swipe pad would leave no room for a cam.
And you're right an aggressive roller cam that could make up for the smaller arc of a roller would most likely hit the cam plates.
Old May 12, 2002 | 04:30 AM
Prelude Vtec 23's Avatar
True, it does eliminate vtec.
Old May 12, 2002 | 11:01 AM
vspec12's Avatar
New User
do you think a skunk2 stage 2 cam would work well w/ this setup?
i checked crane site, and they are not available yet?!? haven't they been out for awhile?
Old May 12, 2002 | 10:21 PM
earl's Avatar
Sometimes I wonder why I bother to post
Old May 12, 2002 | 10:28 PM
Rocket's Avatar
Because you like to help people.
Old May 12, 2002 | 10:37 PM
Rocket's Avatar
You guys have to realize that the lobes on a roller cam have to be much fatter. Most aggressive roller cams look like they have square lobes.
Stock style cams have assymetrical profiles with a flat side and a arc side to properly interact with the arc on the swipe pad of the rocker.
[Modified by Rocket, 6:01 PM 5/13/2002]
Old May 13, 2002 | 05:56 AM
earl's Avatar
Is there any cure for that
Old May 13, 2002 | 06:42 AM
bigTom's Avatar
look up
2k.civic.si
Jul 1, 2013 07:58 PM
yfz
Sep 27, 2012 01:59 PM
