TIRE PRESSURE
Old Dec 6, 2006 | 09:28 AM
jonzel's Avatar
Default TIRE PRESSURE
I have a 95 LS Integra w/ 15 inch gsr rims.
Tires are Falken ZE512 205/50/15.
Any one know what tire pressure I should use?
Old Dec 6, 2006 | 09:30 AM
AllMotorDan's Avatar
30-35 for everyday driving is fine
Old Dec 6, 2006 | 10:34 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You should run stock air pressure settings regardless of tire size.
35 in front and 32 in back, according to the owners' manual.
Old Dec 6, 2006 | 01:04 PM
s2kdre's Avatar
Default Re: (PatrickGSR94)
30psi cold is perfect.
Old Dec 6, 2006 | 08:11 PM
Community Builder
Default Re: (s2kdre)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2kdre &raquo;</TD></TR><TR><TD CLASS="quote">30psi cold is perfect.</TD></TR></TABLE>
That's too low. It should be 35 front and 32 rear, measured when cold.
Old Dec 6, 2006 | 09:25 PM
99Geeezer's Avatar
Default Re: TIRE PRESSURE (jonzel)
refer to the sticker in your door jam.
Old Dec 6, 2006 | 09:30 PM
vinai's Avatar
Most people use the tire pressure recommended on the side wall of the tire. Just a thought though....
Old Dec 7, 2006 | 05:04 AM
Community Builder
Default Re: TIRE PRESSURE (vinai)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinai &raquo;</TD></TR><TR><TD CLASS="quote">Most people use the tire pressure recommended on the side wall of the tire. Just a thought though....</TD></TR></TABLE>
NEVER use what is listed on the tire. That is the maximum pressure the tire can take, and if you run that, the center portion of the tire tread will wear out in no time, not to mention traction will be quite a bit less than with factory tire pressure specs.
How do I know? On my old car I ran nearly 40 psi in the front, 205/50-16 tires when I should have had 35 in them. In less than a year the center of the tread was toast.
Old Dec 7, 2006 | 06:37 AM
Sam92Teg's Avatar
Default Re: TIRE PRESSURE (99Geeezer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Geeezer &raquo;</TD></TR><TR><TD CLASS="quote">refer to the sticker in your door jam. </TD></TR></TABLE>
^^best advice^^
Funny, my door jam on my 92 RS says to use 29 lbs and 60 lbs for the spare, cold.
I remember reading a thread like this about a year ago and took the advice to use 35. Well, the middle tread on the tire wore out quickly because it was overinflated.
That was on 205/50/15's. Now they wear sweet with 30 lbs.
Modified by Sam92Teg at 8:00 AM 12/7/2006
Old Dec 7, 2006 | 06:40 AM
Wraith_G2IC's Avatar
Default Re: TIRE PRESSURE (PatrickGSR94)
Ditto what PatrickGSR94 said. Although it is different for G2s and G3s, so check the sticker.
The major problem with this statement is "most people" are complete RETARDS when it comes to cars. Even the ones that pretend to know something. Spread knowledge, not ignorance.
Old Dec 7, 2006 | 06:58 AM
i agree with patrickgsr also, i only said go with 30-35 because he told us his tire size. when i got my new rs i noticed the sticker on the door jam told me to use 29lbs
Old Dec 7, 2006 | 09:31 AM
jonzel's Avatar
Default Re: (SpoonSirG)
My door jam says 29 psi. But I thought that seemed a little low.
That 29 psi was for the original 195/60/14, not my 205/50/15.
I thougth that the pressure repuirements might change for the different tires & rims.
Old Dec 7, 2006 | 09:33 AM
ah yeah, go with patrickgsr's numbers 35F 32R
Old Dec 7, 2006 | 10:20 AM
Default Re: (jonzel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonzel &raquo;</TD></TR><TR><TD CLASS="quote">My door jam says 29 psi. But I thought that seemed a little low.
The recommended tire pressure is not a direct function of the size. It is a balance of the tires load capacity, car's weight, and overall ride, performance, etc..... Just because you went up one inch (or 2 or 3) doesn't mean squat in the "big picture". Most tires you will fit on an Integra will have "similar" load capacities, and you didn't severely change the weight of your car, so there is no need to throw the stock PSI out the window. Now if you switched to any given size tire that is "SIGNIFICANTLY" harder or softer than stock then play around with +/- 1 to 5 psi. IE - if you run a super soft tire, you may find that you need a few more pounds to get them to wear properly, and the reverse for a super hard compound.
Bottom line - you won't need to over-think this maintenance step. Just follow Acura/Honda's recommendations with small variations for different tire compounds
pnoi_01dc2r
May 28, 2007 07:24 AM
ExiledinIN
Apr 20, 2005 07:24 AM
Floored
Apr 20, 2005 06:57 AM
Understeer
Oct 15, 2003 07:59 AM
RatRedV8Datsun
Apr 16, 2003 05:26 PM
