steering wheel vibrates stopped
Old Dec 6, 2006 | 07:18 AM
alwaysoverkill's Avatar
Default steering wheel vibrates stopped
Hey guys,
My 93 DX just got an engine swap to a D15B and when in park or neutral its perfect. Put the car in drive though and foot on the brake (like at a stop light) the steering wheel vibrates quite a bit. Anything I can do? its just annoying.
Old Dec 6, 2006 | 07:27 AM
dohcdelsol's Avatar
Default Re: steering wheel vibrates stopped (alwaysoverkill)
did you upgrade the motormounts??? or put new one's on?? Normally that type of vibration could be from the mounts and any one of the bushings
Old Dec 6, 2006 | 07:28 AM
EJ1 wilcox's Avatar
Default Re: steering wheel vibrates stopped (dohcdelsol)
Mine vibrates a lot as well, but I have urathane motor mounts.
Is your idle set correclty? How about your timing?
Old Dec 6, 2006 | 08:43 AM
mounts are stock. Idle is perfect, it just vibrates the wheel alot....also the exhaust, but that I know is a busted hanger.
Old Dec 6, 2006 | 08:45 AM
NonovUrbizniz's Avatar
Loved
Default Re: (alwaysoverkill)
It's most likely one of the lower torque mounts the ones that mount to the frame rails down low...
Those tear and allow the engine to shake quite a bit.
The idle is raised and there is more tension when it's in drive as opposed to park... so it's more likely to shake then.
Herbie
31
May 13, 2015 06:34 PM
raverx3m
Mar 10, 2015 08:15 PM
Uljima
Apr 8, 2014 08:07 PM
raverx3m
Nov 24, 2010 04:11 PM
216.226.142.95:27016
Nov 27, 2003 10:34 AM
