MSD REMOVAL HOW TO????????? just change the dizzy cap and unhook the wires and DONE??
Old Dec 6, 2006 | 04:05 AM
Kangolbrand's Avatar
Default MSD REMOVAL HOW TO????????? just change the dizzy cap and unhook the wires and DONE??
How to remove a MSD set up? What to do, what not to do, what should I know before trying?
its for sale by the way if anyones interested, off a obd2 gsr
Old Dec 6, 2006 | 05:59 AM
crxnj's Avatar
Default Re: MSD REMOVAL HOW TO????????? just change the dizzy cap and unhook the wires and DONE?? (Kangolbra
1st unhook the battery,get a new oem style cap,then just remove the system completly...Where the wires were spliced into your car's harness,simply remove msd's wires and reconnect the factory wires like stock(just match the colors)..i recomend solder and heatshrink if the wires were cut,,,or if they were just spliced halfway you can just tape them up real tight with good electrical tape..
Old Dec 6, 2006 | 08:26 AM
CleanLikeJdm's Avatar
Hype-R Stalker
You need new internals for the dizzy if you're doing that part though,
It would actually be a lot easier to buy another dizzy, and put that one in.
I do have an empty dizzy shell though from having an msd pack on it if you needed pics,
and then a distributor which is just missing one part, but it's stock, and mostly full.
Old Dec 6, 2006 | 08:38 AM
quis23's Avatar
the only part missing in the dizzy would be the coil .
Old Dec 6, 2006 | 08:39 AM
dc4teg95's Avatar
remove evrthing and put back together in reverse order. but u will need a internal coil. i do have a obd 2 internal coil from a ls. im not sure if they are the same though
ub3rn00ber
13
Oct 22, 2012 10:23 AM
Shoei7
Jun 5, 2007 05:14 PM
redDAinteg
Jul 5, 2005 02:47 AM
EKCivicR
25
Aug 23, 2004 07:53 PM
turbolshatch
Apr 19, 2004 04:52 PM
