Jet bandsaw
Old Dec 5, 2006 | 07:45 PM
turboekcivic's Avatar
Default Jet bandsaw
How could I make collectors using a jet HVBS-7MW bandsaw. Is there a trick to it or do I have to make some kind of jig to do so. I want to make my own collectors for turbo manifolds and have them cut consistently. Its a horizontal bandsaw by the way. Please help. Thanks.
Old Dec 6, 2006 | 12:21 PM
Default Re: Jet bandsaw (turboekcivic)
Anyone? I guess its a secret huh?
Old Dec 6, 2006 | 04:28 PM
9bells's Avatar
OG Fabricator
A jig that you clamp/ bolt onto the table would work to get the perfect angle.
If it doesn't have a good size table, make one, then make the jig.
You would have to have one cut as desired first, then use it to set-up the jig.
Just get the piece to run parallel to the blade on the cut side, and affix something to the table to hold it there. Either tap the table and bolt it on, or clamp with a bessey clamp,etc. Spring clamps are not recommended for anything with vibrations, as it can disengage the clamp and cause serious injury/damage.
example: visegrips...
Old Dec 6, 2006 | 04:39 PM
Howitt's Avatar
Default Re: Jet bandsaw (9bells)
people act like Collectors and cutting elbows are a secret as building a atom bomb. Ill post my jigs here next week and if the mods want they can make it a sticky Ill prob buy a harbor freight band saw since that what everyuse is using these days.
UNforgivABLE
Suspension & Brakes
21
Jun 30, 2009 12:24 AM
Luckywhiteboi
Mar 6, 2009 03:58 AM
higgunscrx
Welding / Fabrication
May 1, 2007 08:57 PM
hmtcrxsir
Nov 7, 2005 01:02 AM
DragII
Jan 3, 2002 02:10 PM
