What are all the parts to do 5th gen SS to 5spd?
Old Dec 5, 2006 | 06:51 PM
Kurin's Avatar
Default What are all the parts to do 5th gen SS to 5spd?
Since having my transmission rebuilt(best case scenario from a friend's friend) is going to cost me $600->$1300, I was considering to just have him do a 5 speed swap instead, and avoid future problems with the auto. What all would I need to do the swap?
Old Dec 5, 2006 | 06:53 PM
mgags7's Avatar
you need a couple of vtec converters, a jdm headlight, some nuts/bolts, and a motec full system exhaust
hit the search bud
Old Dec 6, 2006 | 07:48 AM
Kurin's Avatar
Default Re: (bb4ever)
I did search, both manually and with the search button. I didn't find the information I needed, so I made the topic.
Old Dec 6, 2006 | 08:27 AM
roller3804's Avatar
Default Re: (Kurin)
Lets see here.
LIST:
Manual h22 tranny(m2f4,m2b4,m2a4 etc...)
Manual Flywheel and bolts
Clutch & Pressure Plate and bolts
Manual intermediate shaft and bolts
manual obd2 ecu
Manual driverside and passenger side driveshafts
Shiftlinkage and bolts
Master and slave clutch cylinders and bolts
Clutch fluid hardlines and bolts
Manual Pedal assembly and bolts
Manual Shifter console and bolts
Manual Shifter assembly and bolts
And you might need a manual transmission mount.
Old Dec 6, 2006 | 08:51 AM
Kurin's Avatar
Default Re: (roller3804)
Thanks, roller. I'll start looking for these parts now. I appreciate the help.
Old Dec 6, 2006 | 11:00 AM
mgags7's Avatar
dont forget:
a brain
a multimeter
soldering iron or some butt connectors
a few feet of wire to do the reverse switch, and the starter cut stuff
again if you search appropriately you can find it, I made a thread on this already
Old Dec 6, 2006 | 01:36 PM
roller3804's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">dont forget:
a brain
a multimeter
again if you search appropriately you can find it, I made a thread on this already</TD></TR></TABLE>
whats a multimeter and what would you need it for??
And I said manual obd2 ecu
eusdmg
Sep 27, 2009 02:19 PM
ragnarok0mega
Jun 4, 2009 04:14 AM
drmay
Jan 22, 2007 05:25 PM
100bhp
Aug 28, 2003 03:18 PM
