aftermarket steering wheel, removing airbag wires???
Old Dec 5, 2006 | 03:30 PM
dohcdelsol's Avatar
Default aftermarket steering wheel, removing airbag wires???
I want to remove my stock steering wheel with airbag on my 92 civic and replace it with the NRG QR, Hub, and steering wheel of my choice. The only question i have is if i pull the stock steering wheel, do i have to remove all the wires for the airbag and cruise control or can i simply disconnect it and not have to worry about a SRS light etc???
Old Dec 5, 2006 | 04:22 PM
schardbody's Avatar
you will have an SRS light nomatter what, pull it out the cluster and just disconnect the wires.
Old Dec 5, 2006 | 05:28 PM
crimsonv4mpire's Avatar
Default Re: (schardbody)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody &raquo;</TD></TR><TR><TD CLASS="quote">you will have an SRS light nomatter what, pull it out the cluster and just disconnect the wires.</TD></TR></TABLE>
you can jump the clip!
Old Dec 5, 2006 | 08:02 PM
dohcdelsol's Avatar
Default Re: (crimsonv4mpire)
If i disconnect the airbag, will that set the SRS light off???
and no im not going to pull it out the cluster
Old Dec 5, 2006 | 09:38 PM
dafuzzbudd's Avatar
Default Re: (dohcdelsol)
if you'r pulling the bag there's no other option than to cheat it
pull the bulb or jump the wire (do you need a resistor?)
skunk_duece's Avatar
You'll have an SRS light no matter what you do, so man-up and pull the cluster or live with the annoying orange light staring you down forever.
Old Dec 5, 2006 | 09:40 PM
b-h-b's Avatar
Default Re: (skunk_duece)
cover light with electrical tape
Old Dec 5, 2006 | 09:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crimsonv4mpire &raquo;</TD></TR><TR><TD CLASS="quote">
you can jump the clip! </TD></TR></TABLE>
You can't fool the SRS light with a paper clip MacGyver, I believe I read on here once a honda technician rigging-up an very elaborate set-up of resistors with a relay, and it worked for like 3 days, he ended-up pulling the bulb.
Old Dec 5, 2006 | 09:47 PM
BlueIntegraBoy's Avatar
Default Re: aftermarket steering wheel, removing airbag wires??? (dohcdelsol)
Just unplug the SRS plug from the back of the gauge cluster. No more SRS light.
Old Dec 5, 2006 | 09:54 PM
Default Re: aftermarket steering wheel, removing airbag wires??? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Just unplug the SRS plug from the back of the gauge cluster. No more SRS light.</TD></TR></TABLE>
in EGs the SRS light does not have it's own plug, and unless you got hands like a circus midget you aren't gettin to the big plug without loosening the cluster at which point why not just pull the bulb?
Old Dec 5, 2006 | 10:00 PM
Eran's Avatar
HT White Ops
If you want to keep the function of your passenger airbag, you'll have to do this:
https://honda-tech.com/zerothread?id=1760922
But yes, you can remove the wires. You just unscrew the clock spring (srs cable reel) and remove it.
Once you've made your spoof jumper, you can follow these instructions to get rid of the SRS light:
https://honda-tech.com/zerothread?id=976465
Old Dec 5, 2006 | 10:01 PM
Default Re: aftermarket steering wheel, removing airbag wires??? (skunk_duece)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk_duece &raquo;</TD></TR><TR><TD CLASS="quote">
in EGs the SRS light does not have it's own plug, and unless you got hands like a circus midget you aren't gettin to the big plug without loosening the cluster at which point why not just pull the bulb?</TD></TR></TABLE>
The yellow plug is the SRS plug
Old Dec 5, 2006 | 10:06 PM
Eran's Avatar
HT White Ops
The yellow plug is the SRS plug</TD></TR></TABLE>
Yep. In the EK I didn't even look to pull the bulb, I just pulled the plug. I no longer have airbags.
Old Dec 6, 2006 | 06:02 AM
dohcdelsol's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">If you want to keep the function of your passenger airbag, you'll have to do this:
i dont have a pass airbag.
guess ill be pulling that bulb then....
Old Dec 6, 2006 | 07:57 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol &raquo;</TD></TR><TR><TD CLASS="quote">
guess ill be pulling that bulb then....</TD></TR></TABLE>
Just pull the yellow plug out of the back of the cluster
Old Dec 6, 2006 | 08:27 AM
Nate047's Avatar
Default Re: (b-h-b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b-h-b &raquo;</TD></TR><TR><TD CLASS="quote">cover light with electrical tape </TD></TR></TABLE>
ghetto...
if you only unplug the actual light bulb, will your passenger bag still deploy?
i know the O.P does'nt have one in his particular car, I mean in general...
Old Dec 6, 2006 | 08:33 AM
Eran's Avatar
HT White Ops
If you unplug one airbag, and don't reset the SRS system, then no, the other airbag won't deploy.
Old Dec 6, 2006 | 09:21 AM
Nate047's Avatar
Default Re: (Eran)
thanks, good to know!
pyro13
Apr 2, 2009 08:40 AM
bmxpunk
Jul 29, 2008 07:28 PM
lightbulb2k7
Jun 22, 2007 12:28 AM
Rene M
Oct 11, 2006 02:43 PM
cdfive.
Apr 25, 2005 05:57 PM
