converting to front brakes from 95 integra
I have the whole front brake setup from a 95 integra that i can use. I have an 89 civic std and the brakes are starting to go out, so I'm wondering if I can swap out the whole thing with the one from an integra. seems like the axles slines different. can I just use the rotor and the caliper from the integra? would it just bolt in or would i have to modify?
thx
thx
your gonna have to use the whole steering knuckle, i just did the whole integra setup(front and rear) on my 91 civic, i got mine from a 92 gsr. there awsome! good luck--
Up from the dead
I read that to keep the camber correct you need to swap over to the Integra upper A arm as well as the knuckles.
Does this only apply to the DA's?
I'm swapping over to '98 Integra front and rear brakes and was wondering if I should pull the upper A arm as well as the knuckle assembly?
Anybody know for sure? I may just pull it out anyway.
i recently tried putting jdm eg front spindles on my 91 crx and it had mad + camber... if someone knows the correct upper control arm to use it would be awsome!
Which upper arm did you use to end up with positive camber?
As far as I know the EG and DC arms are the same, so if you used the EG arm and ended up with positive camber, I assume getting the DC arm would be pointless.
Is it not possible to use the stock EF arm with the DA/EG/DC knuckle?
i used the ef upper control arms... it might have bee able to be corrected using a camber kit backwards, and probably would have given more room for slicks but the rest of the unknown was what i was afraid of...
Hatchback_Pat
Oct 14, 2012 10:16 PM
Cap'N Chronic
Feb 8, 2012 11:11 AM
nothing_shocking
12
Oct 30, 2009 08:32 AM
LSEGHATCH
Sep 26, 2005 10:15 PM
