2001 Prelude
Need some advice. I have a 2001 Prelude and I'm ready for the 105,000 mile maintenance. Would it be recommended that I have the water pump changed at this time regardless of the condition? Any positive or negative experiences out there? Any advice on the maintenance. I have called a number of Honda dealers and they all give me different story on their 105 maintenance requirements. Feel like calling Honda and ratting their asses out.
Any advice is appreciated.
It's real easy to replace while you've got all the covers off and you are doing the belt, if you leave it & the pump starts to fail then you have to remove it all again to get at the pump. Plus it's peace of mind for the relative small cost, knowing it's new & not likely to fail in the near future and cause engine damage.
You don't need a new oil pump by any means. List of things to do:
Tbelt- while changing the tbelt, convert from auto tensioner to manual tensioner
Waterpump
Brake fluid
Coolant
Clutch fluid
Valve adjustment
Transmission fluid
Air Filter
Waterpump
Brake fluid
Coolant
Clutch fluid
Valve adjustment
Transmission fluid
Air Filter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">You don't need a new oil pump by any means. List of things to do:
Waterpump
Brake fluid
Coolant
Clutch fluid
Valve adjustment
Transmission fluid
Air Filter</TD></TR></TABLE>
I've been told to replace the cam seals, too. any truth to this?
Waterpump
Brake fluid
Coolant
Clutch fluid
Valve adjustment
Transmission fluid
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rniederlando »</TD></TR><TR><TD CLASS="quote">
I've been told to replace the cam seals, too. any truth to this?</TD></TR></TABLE>
That wouldnt hurt, those along with the cam cap too. They always tend to leak.
Here's a list of things to change
-Timing belt
-Water pump
-Front main seal
-Cam seal
-Valve adjustment
-Coolant
-Auto to Manual tensioner coversion
-Cap and rotor
-spark plugs
-Timing belt
-Water pump
-Front main seal
-Cam seal
-Valve adjustment
-Coolant
-Cap and rotor
-spark plugs
Excellent thanks for the advice all.
Had the work completed and everything so far has worked out great.
One thing everyone should know. My 2001 Prelude has 99,000 miles on it and the timing belt and or tensioner was making a noise. Had the work completed and the noise is gone. I did not ask the dealer if the belt was clearly worn or the tensioner was trashed. My main point of the post is that the belt would NOT have made the recommended 105,000 mile change. I've had a number of them changed over the years and all looked relatively new when changed and all looked like they could have lasted many more miles. Not the case in this situation. Just an FYI to all.
Anyways, thanks for the advice.
aschweizer2007
Sep 21, 2018 07:22 PM
Synthead
Mar 5, 2005 10:00 PM
