anyone know if i can safely run 88mm bore on stock H22a sleeves?
Old Dec 5, 2006 | 07:48 AM
hondafiend's Avatar
Default anyone know if i can safely run 88mm bore on stock H22a sleeves?
anyone know if i can safely run 88mm bore on stock H22a sleeves? got some 88mm pistons and want to see if i can safely bore the stock 87mm sleeve to 88mm?/ anyone??
Old Dec 5, 2006 | 05:19 PM
ESP-net
Guest
Posts: n/a
Default Re: anyone know if i can safely run 88mm bore on stock H22a sleeves? (hondafiend)
Nope...ALL H series engines have FRM cylinders H22/H23...different from the other Honda Cylinders...
Only way to run 88mm pistons would be getting the high dollar Iron Sleeves...
turbo_d
Nov 17, 2009 06:10 PM
94CDMeg
Sep 25, 2008 07:47 PM
Nandezuk
Jun 10, 2005 11:52 PM
ID_ten_T
May 27, 2003 10:35 PM
