my problem with b18/b20 buildup
Old Dec 5, 2006 | 05:52 AM
namm's Avatar
Default my problem with b18/b20 buildup
i have a b20z block & i'm gettin an b18c5 (crank) j-spec from a spoon n1 moto!
i want to run civic typeR rods with some 12.1 compression pistons with jun stage 3 cams, spring/retainer (crower) & a 1off custom toda/4age 4i.t.b. ecu is chrome and 375cc injectors with a walbro 255pump,typeR flywheel & crank pully.
but most of all the block will be shaved for that stroke & it will still retain the stock sleev so my question is can it hold up?????
i would to make around 235whp cause i'll be revvin the hell out of it
so how dose 9500rpm sound?
and do you think i can make 155 ftlb??
but can the block hold up???
Old Dec 5, 2006 | 06:14 AM
namm's Avatar
Default Re: my problem with b18/b20 buildup (namm)
sorry some mistake was made on that post, #1 it will running b18c R crank & b18c rods.
question......! can the block holdup with the stock sleev? i've seen alot of them crack on the sleev.
Blacksole
Jan 12, 2011 10:32 PM
dannyneedshelp
Oct 15, 2008 09:22 PM
philliedawg
13
Sep 4, 2008 03:08 AM
lakai_19
Feb 13, 2008 04:08 PM
SiRkid
Jun 9, 2002 09:32 AM
