any help with cel codes
Old Dec 4, 2006 | 10:45 PM
latinracerct's Avatar
Default any help with cel codes
i did mpfi swap and my ecu is throwing out code 10 and 14 its a pm6 91 si ecu i also wanna know if someone knows why my cars skipping like hold back when i punch it someone told me my dizzys goin bad it only happens when i run it hard but when im driving normal speeds car runs good please any help will be appreciated thanks
Old Dec 5, 2006 | 11:10 PM
Mavrick's Avatar
Default Re: any help with cel codes (latinracerct)
maybe if you spoke english instead of jargon we could understand your problem
Old Dec 6, 2006 | 01:24 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: any help with cel codes (Mavrick)
10 IAT Intake Air Temperature
14 IACV Idle Air Control Valve
Make sure you have both of these plugged in and if you do make sure they aren't reversed since they use an identical style plug (round plug with a slot on the side)
callmetree19
Dec 8, 2008 09:42 AM
Hatch93Back
Aug 17, 2004 08:00 AM
B00ST2nR
May 12, 2003 07:15 PM
B00ST2nR
Apr 18, 2003 03:35 PM
