PCV valve
Old May 10, 2002 | 10:17 AM
outlaw racer's Avatar
Default PCV valve
ok, i took my intake manifold off yesterday to clean it up a bit, anyway i broke the PCV (positive crankcase ventilation) valve. im thinking of running a stright line from the crankcase liquid-vapor seperator (breather chamber) directly to the intake until i get it fixed.. this would essentially bypass the PCV valve all together. does anyone know off hand if this would cause any problems?? the motor is a b16a
Old May 10, 2002 | 10:29 AM
BSQ's Avatar
BSQ
Default Re: PCV valve (outlaw racer)
The breather camber will have "full" vacuum all the time, since the PCV valve controls the amount of vacuum. This may lead to an increased amounts of oil in the intake runners.
Old May 10, 2002 | 10:32 AM
eerieCivic's Avatar
Default Re: PCV valve (BSQ)
But if you want to do it, just get about a foot of 3/8" (I think that's the right size) tubing and a couple hose clamps. What are you gonna do about the air bypass to the intake if the PCV is gone though?
Old May 10, 2002 | 04:37 PM
aeolus's Avatar
Default Re: PCV valve (eerieCivic)
Your engine will idle kinda high cuz it will be like it has vacuum leak.I tried it already,it doesnt work.
zeroek
Apr 3, 2011 04:07 PM
DuhQbnSiLo
Jun 26, 2009 08:34 PM
AZNracerx1989
Jan 27, 2006 09:38 PM
eluder33
Mar 24, 2005 11:19 AM
Reelizmpro
Nov 17, 2004 05:16 PM
