flickering hids?
Old Dec 4, 2006 | 08:14 PM
bullittsvt's Avatar
Default flickering hids?
i just bought hids for my 03 ep and i tried installing them. i installed them correctly and checked the connections but the lights keep flickering? i even changed the power fuse to 20a and they still flicker? and input is appreciated! thanks
Old Dec 4, 2006 | 08:26 PM
cnyej1's Avatar
Default Re: flickering hids? (bullittsvt)
Bad connection somewhere.
Old Dec 5, 2006 | 06:00 AM
Type X's Avatar
is the car on when your testing them?
sometimes if a car has an aftermarket hid system one light will turn purple etc etc
you need to have the car running then turn them on
if it STILL flickers... check all the connections
DO NOT UP ANY FUSES anywhere
Old Dec 5, 2006 | 07:36 AM
bullittsvt's Avatar
so check the connection from the socket to the hid..then from the hid to the ballasts? are those the only connections im supposed to check? because everything looks like its plugged in fine...
Old Dec 5, 2006 | 08:16 AM
Type X's Avatar
Default Re: (bullittsvt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullittsvt &raquo;</TD></TR><TR><TD CLASS="quote">so check the connection from the socket to the hid..then from the hid to the ballasts? are those the only connections im supposed to check? because everything looks like its plugged in fine...</TD></TR></TABLE>
properly grounded....connections are fully plugged in, no crimps in wires... connections aren't dirty etc etc
Old Dec 5, 2006 | 03:00 PM
bullittsvt's Avatar
yea the connections look good...everything is plugged in fine...when i plug in one it flickers and when i plug both of them in then nothing happens...
Old Dec 6, 2006 | 04:55 AM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullittsvt &raquo;</TD></TR><TR><TD CLASS="quote">yea the connections look good...everything is plugged in fine...when i plug in one it flickers and when i plug both of them in then nothing happens...</TD></TR></TABLE>
ok than you bought cheap junk lol
Old Dec 6, 2006 | 07:52 AM
bullittsvt's Avatar
http://cgi.ebay.com/ebaymotors...d=1,1
Old Dec 6, 2006 | 08:11 AM
cnyej1's Avatar
Stupid question....are your Highbeams on? I bet this is a low beam only kit, and if thats the case if you had your high beams on nothing would work.
Also, its a cheap kit.
Old Dec 6, 2006 | 08:28 AM
tonyr's Avatar
You should get your money back.... When it comes to HIDs if you wana go cheap you have to be real careful...
Old Dec 6, 2006 | 09:07 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: (tonyr)
I had the same problem, on of the wires was ground it self on the frame.
Old Dec 6, 2006 | 10:02 AM
bullittsvt's Avatar
Default Re: (cbmprelude)
how do i fix it? sorry im a noob to this electrical stuff...
Old Dec 6, 2006 | 12:53 PM
Type X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullittsvt &raquo;</TD></TR><TR><TD CLASS="quote">how do i fix it? sorry im a noob to this electrical stuff...</TD></TR></TABLE>
grind down the area (or sanding)
there should be NO PAINT where you drill the ground to the car
OR if its a ring
use a bolt.... that say...holds to the frame
Old Dec 7, 2006 | 10:36 PM
bullittsvt's Avatar
i wrote the guy and he wrote me back saying that i needed some relay that connects to the battery or something? im gonna get more info on what hes tryin to tell me but thanks for the tips...by the way thats a sickkk si u got there..
Old Dec 8, 2006 | 12:58 AM
nautica_t's Avatar
i guess that what happens when you stimp out...you got a shitty kit..
i hope nothing happens to your EP.
Old Dec 17, 2006 | 04:30 PM
Thizzed Out's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bullittsvt &raquo;</TD></TR><TR><TD CLASS="quote">i wrote the guy and he wrote me back saying that i needed some relay that connects to the battery or something? im gonna get more info on what hes tryin to tell me but thanks for the tips...by the way thats a sickkk si u got there..</TD></TR></TABLE>
relay? so that pretty much means you should up grade your light harness.
driveby4082
Sep 30, 2011 03:22 PM
AK94GSR
May 11, 2007 04:15 PM
Rayz_Si
Oct 16, 2006 06:29 PM
r0c5t4r
Mar 28, 2004 03:21 AM
GeorgeY
Feb 2, 2003 11:27 AM
