FS 1994 Civic Ex GSR swap, JRSC, Volk Te-37, more
After having this car for a long time and devoting a lot of time and money in it, I am considering selling it. I bought the car in 2001 and have done everything to it myself. It has gone through many changes and though it has now got to where I want it, but I am considering moving on. I am firm with my prices, so don't try lowballing.
Prices are
$8000 as is
Deduct $500 if you want ls mesh instead of the volks
Deduct $500 if you want stock speakers with the Eclipse deck only
Deduct $1000 if you want no supercharger (I will throw on an aftermarket intake mani and retune it on the dyno)
Drivetrain:
JDM B18c (1997 SIR-G)
Factory LSD equipped transmission (no grinds)
ACT Prolite flywheel
ACT HDSS clutch
DC DAC intake w/ AEM air filter
Comptech header
JRSC @ 5.5 psi
Golden Eagle cam gears
ITR valve cover cut for cam gears
RC 440 cc injectors
Walbro 255 hp fuel pump
B&M fuel pressure regulator
Fuel pressure gauge
p28 tuned via Crome Pro
Skunk2 short throw shifter w/ Skunk2 shift ****
Energy Suspension shifter bushings
Apexi WS2 catback exhaust
High flow cat
Exterior:
Mystic Blue Metallic paint job (2003 BMW M3 color)
(The engine bay, jambs, and trunk were all shot with Dupont basecoat/clearcoat)
Volk Te37 15" wheels in white
Kumho 712 tires
JDMsh$t carbon hood (grade AA w/ rolled edges)
Brakes/Suspension:
KYB AGX shocks front and rear
Neuspeed sport springs for DC Integra
Skunk2 camber kit (front)
SPC rear lower control arms
Brembo slotted rotors
PBR brake pads
Spoon Sports front upper strut bar
Interior / Audio:
Integra GSR cloth front seats
Integra Leather steering wheel
Audio Console w/ boost gauge installed
JDM arm rest
Eclipse CD5435 head unit
Eclipse Sirius tuner (direct connection)
Eclipse 5 channel amplifier
Eclipse 10" aluminum sub
Rockford Fosgate 5.25" FNQ component speakers (front)
Rockford Fosgate components w/ OZ audio drivers (rear)
Stinger 0 gauge wire
Stinger Dream series interconnects
Stinger Roadkill expert throughout trunk and rear panels
Stinger Roadkill on door skins and door skeletons
Security system w/ tilt/motion/shock sensors, remote start (safe w/ manual transmission)
below are pics and other pics can be found here
https://honda-tech.com/zerothread?id=1769382
https://honda-tech.com/zerothread?id=1662409
https://honda-tech.com/zerothread?id=1179721
Prices are
$8000 as is
Drivetrain:
ACT HDSS clutch
Comptech header
JRSC @ 5.5 psi
RC 440 cc injectors
Fuel pressure gauge
High flow cat
Exterior:
Kumho 712 tires
Brakes/Suspension:
PBR brake pads
Interior / Audio:
JDM arm rest
