Is there an easier way to remove a nut and bolt?
Old Dec 4, 2006 | 05:14 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Is there an easier way to remove a nut and bolt?
For the life of me, I have been wrestling with this god forsaken header for too long now. I am trying to remove the nuts and bolts at the cat; the ones with the springs.
I've already sprayed penetrating oil and tried using one of those bolt-out kit but I am still struggling.
if you have a simpler way to remove ths crap, please let me know asap.
Thanks.
Old Dec 4, 2006 | 05:18 PM
sicones's Avatar
Default Re: Is there an easier way to remove a nut and bolt? (Jason M)
cut them off, go to the hardware store and buy new ones
Old Dec 4, 2006 | 05:19 PM
all-mtr-teg's Avatar
You can alway cut or grind it off and replace it with a new one. Don't forget to rub some antiseize lube on the new bolt before you tighten it up. That's exactly what i did when i installed my new edelbrock header two weeks ago.
Old Dec 4, 2006 | 05:20 PM
Default Re: Is there an easier way to remove a nut and bolt? (sicones)
The thought had crossed my mind. I think that may be the way to go.
Old Dec 4, 2006 | 07:33 PM
aaronISthrowed's Avatar
I couldn't even get mine off lol.
But for some other tight bolts i use a vice-grip and hammer.
Old Dec 6, 2006 | 09:14 PM
Default Re: Is there an easier way to remove a nut and bolt? (aaronISthrowed)
New header is on... I'm happy. Thanks for the tip.
Old Dec 6, 2006 | 09:16 PM
99Geeezer's Avatar
Nice job. What header did you go with?
Old Dec 6, 2006 | 09:19 PM
integrawow's Avatar
If you couldn't get it to work, I would have suggested either an axe or something that creates high decibel levels with smacked against something. lol
Glad to hear that you got it all sorted out. Great job!
Old Dec 7, 2006 | 12:08 AM
1997 gsr's Avatar
anytime ur struggling with rusted bolt then u can always count on an impact wrench and these sockets i used. the sockets are made to grind away at NUTS. the only thing is that u would need new ones because they would be torn apart
Just1nK4ng
11
Aug 10, 2018 02:41 AM
Atomic1
May 13, 2013 05:55 PM
minilogoguy18
Dec 2, 2009 04:26 PM
the.hamburglar
Jul 23, 2005 09:44 PM
BlueFang08
Mar 13, 2004 11:42 AM
