Bad Thermostat???????
Old Dec 4, 2006 | 04:13 PM
Spence's Avatar
Default Bad Thermostat???????
OK guys so my new daily driver just started doing some wierd cooling stuff.
So as im driving on the freeway the temp gauge will bounce up and down slowly rising then slowly dropping down to normal temp.
When i pull up to a light at idle it will remain at about 3/4 the way but will not overheat
The heat is also affected too it will get really hot when the motor gets hot but it makes no difference if the heat is on or not
Throw your suggestions my way
Old Dec 4, 2006 | 04:23 PM
nappyroots827's Avatar
Default Re: Bad Thermostat??????? (Spence)
it sounds like air in the cooling system...have you changed any cooling system components lately?? try bleeding the cooling system
Old Dec 4, 2006 | 04:41 PM
STREETWERKZ's Avatar
Default Re: Bad Thermostat??????? (nappyroots827)
i agree, i would check that first.
its the cheapest and easiest thing to do.
Old Dec 4, 2006 | 04:47 PM
Spence's Avatar
Default Re: Bad Thermostat??????? (STREETWERKZ)
Well i did change two hoses the one that runs from the block by the therm to the intake manifold, and the one that runs to the fire wall/heater. But the reason i did that is cause the car was overheating so i thought it was that cause it seemed that there was steam coming from there. Before i changed them it was doing this same thing with the up and down of the needle. The bottom hose off the rad was warm then cold today too when i finally go home the bottom rad hose was pretty cold. So ya im stumped
Old Dec 4, 2006 | 09:00 PM
Spence's Avatar
any other ideas?
Old Dec 5, 2006 | 06:11 AM
Spence's Avatar
still need some help guys
Old Dec 5, 2006 | 06:13 AM
shortyz21's Avatar
have u warmed the car up with the rad cap off. keep topping it up..
it really sounds like your coolant is low.
Old Dec 5, 2006 | 07:50 AM
Default Re: Bad Thermostat??????? (shortyz21)
yea, it sounds like your coolant is low....
and as for the temperature change in the lower hose, thats probably because you felt it right before the thermostat opened and then right after so the temperature would have changed....
also, look into the water pump, take off your radiator cap and see if there is a constant flow of coolant coming in
Old Dec 5, 2006 | 10:52 AM
CRXperiment's Avatar
Since your lower hose is cold when you reached op temp, i say your thermostat is stuck closed not allowing proper coolant flow. Same thing happened to me, needle would fluctuate between 3/4 and normal, repacing the thermo was the cure. You should change your thermostat, and bleed your cooling system, also make sure your cooling fan is working. Thermostats are only like 10 bucks.
Old Dec 5, 2006 | 03:52 PM
Spence's Avatar
Default Re: Bad Thermostat??????? (CRXperiment)
ok here is the verdict i must have had a air bubble cause i jacked the car up and burbed the sytem and the car is good to go
Old Dec 6, 2006 | 06:31 PM
Spence's Avatar
ok so it wasnt air in the line so im changing the thermostat tomorrow
Old Dec 7, 2006 | 01:00 PM
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence &raquo;</TD></TR><TR><TD CLASS="quote">ok so it wasnt air in the line so im changing the thermostat tomorrow</TD></TR></TABLE>
Bump for a update.
Old Dec 7, 2006 | 02:19 PM
Spence's Avatar
ok so here is the update i replaced the thermostat and test drove it on the same freeway after to see if it seems fixed. Well right now it does so we will assume its the thermostat if not ill update you again
Old Dec 7, 2006 | 04:51 PM
1991hb's Avatar
my hatch was doing that about 2 months ago so I changed out the thermostat and the temp. sending unit and now it works fine.
Old Dec 8, 2006 | 10:47 AM
Spence's Avatar
Default Re: (1991hb)
Thermostat did not fix the problem. It seems that air is getting into the system as the car sits over night. Is this something that is possible????? Also....as the temp starts to rise, I can hear the car starting to make the fizzle noise from the hose to the heater core.
Old Dec 9, 2006 | 04:06 PM
Spence's Avatar
Ok so here is the update on things burbed the coolant with the nipple on the neck of the coolant hose. It took 15 min at least until i saw actual coolant. So i would not recomend try to burb the system with the cap off and squeezing the hose. I drove the car all day and no over heating so it must have been a huge air bubble.
Old Dec 9, 2006 | 05:17 PM
janz3n's Avatar
you should have run the car with the cap off till the fans come on a few times then put the cap back on and used the "nipple"
Old Dec 9, 2006 | 05:59 PM
Spence's Avatar
Default Re: Bad Thermostat??????? (janz3n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">you should have run the car with the cap off till the fans come on a few times then put the cap back on and used the "nipple" </TD></TR></TABLE>
Ya i did that minus burbing using the nipple
Old Dec 9, 2006 | 06:43 PM
janz3n's Avatar
you dont actually need to do the rad cap thing.. your just supposed to do the nipple but doing both isalways a good thing
jdmchickx
Nov 10, 2011 12:59 PM
mda56
Feb 19, 2011 01:44 PM
sickofitall1113
Feb 12, 2011 08:11 AM
GSR-T-
May 29, 2009 06:46 PM
dc2_dailydriver
Feb 25, 2009 07:06 PM
