Does this flywheel look okay?
Old May 10, 2002 | 09:30 AM
MugenNSX's Avatar
Default Does this flywheel look okay?
B16a stock flywheel lightened and balanced 13lbs. Let me know if you see anything out of the ordinary. I want to get this flywheel but I want to make sure i'm not over looking anything....Thanks for your help!
[Modified by HybridEF2, 10:43 AM 5/10/2002]
Old May 10, 2002 | 09:39 AM
SPOON_BeIgHtEeNsEe's Avatar
Default Re: Does this flywheel look okay? (HybridEF2)
its not ok... cause i just see red X's
Old May 10, 2002 | 09:44 AM
MugenNSX's Avatar
Default Re: Does this flywheel look okay? (SPOON_BeIgHtEeNsEe)
There ya go spoon
HumanResource's Avatar
Those flywheel don't even look like flywheels
they look more square like
i don't know what those X's are from?
keithv's Avatar
its tough for me to see what they did to lighten the flywheel. did you have some holes drilled through it?
the balancing of the flywheel looks good...
Old May 10, 2002 | 09:45 AM
Default Re: Does this flywheel look okay? (Chris90STD)
OH, NOW we're talking
Looks A O K with me!
Just give it a good cleaning before install
Old May 10, 2002 | 09:46 AM
MugenNSX's Avatar
Engine degreaser? what would you use?
Old May 10, 2002 | 09:49 AM
Cereal_Killer's Avatar
engine de greaser would work. simple green would work to.
Old May 10, 2002 | 09:59 AM
flat-blk-HB's Avatar
Default Re: Does this flywheel look okay? (91efzc)
Old May 10, 2002 | 10:33 AM
crxgurlllll's Avatar
wtf are those holes???
also looks like they didnt use 2 holes when it was mounted previously... id be weary
EL Vap133's Avatar
Just get it resurfaced....
Old May 10, 2002 | 10:57 AM
MugenNSX's Avatar
Default Re: Does this flywheel look okay? (Vap133)
I was thinkin the same thing
Old May 11, 2002 | 03:25 PM
HONDABROMANDUDE's Avatar
Are the seats for the flywheel bolts kind of wallowed out? It kind of looks like they are. If so I wouldn't run it because it probably came loose before and the bolts wont seat well anymore. I had to deal with my flywheel coming loose about 5 times because the bolts woulds't seat right. Just make sure where the bolts seat is PERFECTLY flat and smooth.
[Modified by itec311, 12:26 AM 5/12/2002]
[Modified by itec311, 12:27 AM 5/12/2002]
rotascircuit
Dec 22, 2009 10:16 PM
lilo_goki
24
Mar 18, 2008 06:37 PM
NC-B17A
May 9, 2002 08:40 PM
polymath
Feb 7, 2002 11:49 PM
