Window will not go up.
Old Dec 4, 2006 | 04:04 PM
St3v3's Avatar
Default Window will not go up.
1997 Accord 4-door special edition.
My front passenger side window will not go up or down using either one of the switches. All my other windows are fine. After a few attempts to get it to go up with the switches it blows the fuse....Help. Thanks
Old Dec 4, 2006 | 04:32 PM
hondadude's Avatar
Default Re: Window will not go up. (St3v3)
well, rip chuck the door panel off and replace the regulator
Old Dec 5, 2006 | 09:17 PM
No-No's Avatar
try looking for shorts first, i have the same problem but i don't go throw fuses....also look through the arcives on this site this is a common issue on 94-97 accords( windows not going up), a new regulator is 50 bucks if know where to look, cheaper if you have a import junk yard near by, and u pull it. hope this helps
Old Dec 5, 2006 | 11:59 PM
PnX-R's Avatar
Well, I have seen fuses blow due to bad main switches.. But you'll never know until you try it..
HankYee
Feb 14, 2012 08:42 AM
8YourV8
Dec 13, 2010 10:09 AM
silentdork818
13
Aug 7, 2006 11:36 PM
windcalmer
Aug 7, 2004 03:22 PM
