ls/vtec b16 head which power steering pump bracket?
just like it say on the topic. i have a dc shell that i'm droping in an ls/vtec. i don't know which bracket will fit the b16 head or if its the same on gsr and pr3 heads. help so i don't buy the wrong brackets.
is this true i have the same question im doing an lsvtec set up right now and when we went to put the power steering back on and the mounts didnt match up the holes in the head sit up higher on the vtec head as opposed to my ls head.Do i just need that one mount on the front of the head from another vtec head?
LS style bracket is different from the GSR but i belive it uses the same pump. Check part numbers http://www.acuraparts247.com
