power steering bracket for ls vtec?
Old Aug 28, 2004 | 06:55 PM
dcb16's Avatar
Default power steering bracket for ls vtec?
hey guys... i was just wondering what powersteering bracket will work with a 95 ls block and a jdm b16 head.
right now i have a jdm b16 longblock and my ls bracket doesnt work... i know a b16 bracket would, but how will this work with an LS block?
if anyone has done this b4 help me out, thanks ahead of time...
dont tell me to seach, because i did... and do you know how many search results there are for ls vtec?
Old Aug 28, 2004 | 10:26 PM
Octoman's Avatar
Default Re: power steering bracket for ls vtec? (dcb16)
Let's see...
If I remember correctly when my B16 died in my Sol I replaced it with a B20 (same as B18 externally) but I did not swap the head over. Inorder to get the PS to mount up, I had to use a LS upper PS bracket to get it to fit "right" I used some bolts and washers that I bought from the local hardware store and pulled the PS pump up and tight while my brother tightened the bolts for the PS. That may work for you as well. Give it a shot. I got the LS upper bracket from a junk yard for like $5.
Old Aug 29, 2004 | 12:08 AM
dcb16's Avatar
Default Re: power steering bracket for ls vtec? (Octoman)
i already got the bracket... ****, i cant believe i never thought of that... so simple, haha. thanks man.
Old Aug 29, 2004 | 02:49 PM
dcb16's Avatar
anyone else?
Old Aug 29, 2004 | 03:34 PM
Code Blue's Avatar
i have a jdm b16a head on my b18b block. you will need the b16a bracket for the head and i believe the ls bracket for the block, you WILL have to manually tension it, but if you have both the ls and b16a brackets just mix and match them until you have it right...
Old Aug 30, 2004 | 09:03 AM
dcb16's Avatar
Default Re: power steering bracket for ls vtec? (Code Blue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Code Blue &raquo;</TD></TR><TR><TD CLASS="quote">i have a jdm b16a head on my b18b block. you will need the b16a bracket for the head and i believe the ls bracket for the block, you WILL have to manually tension it, but if you have both the ls and b16a brackets just mix and match them until you have it right...
if i have the ls bracket for the block why would i need to manually tension it? the ls bracket has a tensioner... ?
Old Aug 30, 2004 | 04:39 PM
MR-MUGEN's Avatar
i don't really remember how i did it but i ended up taking of my A/C and power steering, but i think i used the b16 bracket for the head and b18 bracket for the block
Old Aug 30, 2004 | 04:49 PM
Code Blue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcb16 &raquo;</TD></TR><TR><TD CLASS="quote">
if i have the ls bracket for the block why would i need to manually tension it? the ls bracket has a tensioner... ?</TD></TR></TABLE>
because the tensioning bolt doesn't line up between the two brackets, this isnt a big deal, as you can pull on the power steering unit then tighten it down, it will work just fine
stelteg
May 1, 2009 09:28 PM
pootie.teng
Feb 2, 2007 05:46 PM
92integra-R
Jun 8, 2006 11:52 AM
Targa4Life
May 24, 2006 02:21 PM
fastbrakes
Oct 12, 2002 01:29 AM
