JDM non-hid headlights??
Old Dec 4, 2006 | 05:40 AM
CDN Yellow ITR's Avatar
Default JDM non-hid headlights??
whats up guys
i about to join the bangwagon n go with the jdm front end but the front end i'm getting the non-hid, but i had a set of hid's for my usdm front end was wondering if the 9006 blub size will fiting into the jdm headlight housing, or is the blub size different then the usdm??? any info would be great
thank you in advance
-tony
Old Dec 4, 2006 | 05:47 AM
Jon D's Avatar
Default Re: JDM non-hid headlights?? (CDN Yellow ITR)
You should use the parts from your kit to retrofit your non-HID JDM headlights. You have all the parts needed except for a good set of projectors, and you will need a new set of bulbs, I THINK!
Old Dec 4, 2006 | 05:57 AM
EEK's Avatar
EEK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">whats up guys
-tony</TD></TR></TABLE>
they fit with no problems. JDM headlights are already a projector so you dont need to retrofit
Old Dec 4, 2006 | 01:42 PM
Black R's Avatar
25 Year Member
And 9006 bulbs fit fine in the jdm non hid headlight housings. the jdm hid housings are the ones that take different bulbs, so you're all good.
Old Dec 4, 2006 | 01:50 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM non-hid headlights?? (EEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK &raquo;</TD></TR><TR><TD CLASS="quote">they fit with no problems. JDM headlights are already a projector so you dont need to retrofit</TD></TR></TABLE>
Not exactly. The JDM halogen housings have projectors designed for use with halogen bulbs, not HID capsules. No, you don't "need" a retrofit, but the output and beam pattern resulting from an HID kit in the halogen housings will not be as good as that of retrofitted HID projectors. In addition, retrofitting will allow you to install projectors with a LHD beam pattern, rather than the RHD-optimised pattern of the JDM lights.
Old Dec 5, 2006 | 05:02 AM
EEK's Avatar
EEK
Default Re: JDM non-hid headlights?? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Not exactly. The JDM halogen housings have projectors designed for use with halogen bulbs, not HID capsules. No, you don't "need" a retrofit, but the output and beam pattern resulting from an HID kit in the halogen housings will not be as good as that of retrofitted HID projectors. In addition, retrofitting will allow you to install projectors with a LHD beam pattern, rather than the RHD-optimised pattern of the JDM lights. </TD></TR></TABLE>
my out put is just fine, maybe even better since its not as strong and not blinding everyone
Old Dec 5, 2006 | 05:19 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EEK &raquo;</TD></TR><TR><TD CLASS="quote">my out put is just fine, maybe even better since its not as strong and not blinding everyone </TD></TR></TABLE>
It may be "just fine" in your opinion, but compared to a true OEM HID setup, halogen projectors with drop-in HIDs produce inferior results. That's just how it is.
Old Dec 5, 2006 | 06:14 AM
Wai's Avatar
Wai
ProFunction/GT Motoring
It may be "just fine" in your opinion, but compared to a true OEM HID setup, halogen projectors with drop-in HIDs produce inferior results. That's just how it is. </TD></TR></TABLE>
I have to agree with it.
"HID kit" used in halogen projectors will not give good results at all.
It's because of the glare, the beam looks "not as strong". And this glare is actually what blinds the on-coming traffic!
Old Dec 5, 2006 | 06:53 AM
Jon D's Avatar
Default Re: JDM non-hid headlights?? (Wai)
There is an absolute difference in using an aftermarket HID kit with the stock projectors found in our cars and retrofitting an oem HID projector. I have both, and the difference is quite signifigant.
We-Todd is down or slow at the moment, when its fixed i will provide examples of both
Old Dec 6, 2006 | 06:24 AM
EEK's Avatar
EEK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Wai &raquo;</TD></TR><TR><TD CLASS="quote">
It's because of the glare, the beam looks "not as strong". And this glare is actually what blinds the on-coming traffic!</TD></TR></TABLE>
Maybe so, but then im sure the police officer who i passed (on coming) that turned around to pull me over wouldve mentioned something about it, but he didnt
Old Dec 6, 2006 | 09:41 AM
GokuSSJ4's Avatar
very true!
having an HID system that its design for RHD doesnt produce the best results on a LHD car.. Even though he might think that the beam patter is ok, you will be suprise at the results on well balance LHD set up will look compare to something that isnt design for it!
Old Dec 19, 2006 | 06:59 AM
exies's Avatar
Default Re: JDM non-hid headlights?? (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">There is an absolute difference in using an aftermarket HID kit with the stock projectors found in our cars and retrofitting an oem HID projector. I have both, and the difference is quite signifigant.
We-Todd is down or slow at the moment, when its fixed i will provide examples of both </TD></TR></TABLE>
Bring back a topic a few weeks old, can you please post the pictures? I'd like to see the difference.
Old Dec 19, 2006 | 07:05 AM
Jon D's Avatar
Default Re: JDM non-hid headlights?? (exies)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exies &raquo;</TD></TR><TR><TD CLASS="quote">
Bring back a topic a few weeks old, can you please post the pictures? I'd like to see the difference.</TD></TR></TABLE>
I would love to but We-Todd is now giving me this msg:
Warning: mysql_connect() [function.mysql-connect]: Too many connections in /web/docs/www.we-todd-did-racing.com/htdocs/includes/mysql.class.php on line 5
mySQL: Too many connections on line 5 in /web/docs/www.we-todd-did-racing.com/htdocs/includes/mysql.class.php
feel free to check it out for yourself.... http://www.we-todd-did-racing.com/
Old Dec 19, 2006 | 08:26 AM
exies's Avatar
Heh I believe you. Just don't forget because I will bring this back from the archives again!
TIA !
phoshyzzle
May 22, 2008 10:42 PM
Emerica
Sep 13, 2007 10:11 AM
. M i c h a e l
Nov 1, 2005 10:02 PM
monalisa overdrive
Oct 19, 2004 08:50 PM
