VALVE STEM
Old Dec 4, 2006 | 12:51 AM
hondasarefast's Avatar
Default VALVE STEM
is there any quick way to do it ur self change the valve stem without the big machine?
Old Dec 4, 2006 | 04:38 PM
thesmogman's Avatar
Default Re: VALVE STEM (hondasarefast)
There is the valve stem, then there is the valve stem seal. The seal you can replace.(The screw in thing inside the valve stem)
The stem itself has to be pulled in from the inside of the rim.
This shouldn't cost you more than $10 bucks at a tire shop, that is if you just bring in the rim. It should not take that long either.
Old Dec 4, 2006 | 04:49 PM
Default Re: VALVE STEM (thesmogman)
yea but i was wondering how hard wuold it be to do it urself at home. has any one done this at home before? without the tire machine?
Old Dec 4, 2006 | 06:34 PM
vtecsi00's Avatar
it is pretty hard to do it at home...you would have to figure out a way to break the bead of the tire off the wheel( just the top bead ).. that is the hard part after that it's pretty much a cake walk...not worth the hassle to just take it in and have the tire guys do it
Old Dec 6, 2006 | 12:47 PM
electron_si's Avatar
Default Re: VALVE STEM (vtecsi00)
yeah i work at goodyear. not worth the hassle. if you go straight into a tire shop through the shop door and just ask a tech there im sure they will do it for free. just roll in there like you own the place, dont bother going to the front counter. i do stuff for people like that all the time. as long as its something small its not big deal
Old Dec 6, 2006 | 08:46 PM
Default Re: VALVE STEM (electron_si)
cooll thanks
higgunscrx
Aug 12, 2008 01:50 PM
zspy_007
Dec 14, 2007 06:25 PM
dyu626
Honda Motorcycles
12
Sep 26, 2007 08:54 PM
chjkingme
Dec 14, 2004 09:52 AM
311
Sep 8, 2004 09:07 AM
